oil idiot light stays on after bike is turned off - Victory Forums - Victory Motorcycle Forum
post #1 of 17 (permalink) Old 04-18-2014, 08:11 PM Thread Starter
bdbaggr's Avatar
Default oil idiot light stays on after bike is turned off
i have 600 miles on new 2014 xc and i just noticed the oil light stayed on after i removed the key for a second or two... right after my 500 mile service. i checked oil, fine, then called shop and mechanic told me that happens sometimes on these bikes... any of you guys have this happen? it doesnt do it all the time intermitant. thanks
bdbaggr is offline
post #2 of 17 (permalink) Old 04-18-2014, 08:19 PM
Even if it happens sometimes it should be fixed under warenty.
2013 cross country tour stock for now
whiskeydave is offline
post #3 of 17 (permalink) Old 04-18-2014, 08:19 PM
rlaws797's Avatar
Mine does it too. Has since day 1. I've been told it's normal-
Ride safe!
Houston, TX
2015 XC Suede Black w/ Red Pinstripes
rlaws797 is offline
post #4 of 17 (permalink) Old 04-18-2014, 08:35 PM Thread Starter
bdbaggr's Avatar
Ride safe!
does it always do it? or intermittently?
bdbaggr is offline
post #5 of 17 (permalink) Old 04-18-2014, 08:46 PM
rlaws797's Avatar
Best I remember, it does it every time.
I don't think it's something to worry about. I forget, but I recall reading somewhere it was normal.
Maybe others will chime in and concur -
Houston, TX
rlaws797 is offline
post #6 of 17 (permalink) Old 04-18-2014, 09:29 PM
Mine does it too.. I'm pretty sure not all the time though but most of the time for sure..!
Victorypotamus
Milesx is offline
post #7 of 17 (permalink) Old 04-18-2014, 10:01 PM
pull wire off sending unit and clean it. The sending unit is right behind the end of the kickstand if it was up.
post #8 of 17 (permalink) Old 04-18-2014, 10:51 PM
I have a 2012 XC and it does the same thing and has since it was brand new.
oklahomamaskedman is offline
post #9 of 17 (permalink) Old 04-19-2014, 04:24 AM
GatorJoe's Avatar
2012 XC and has never done it ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #10 of 17 (permalink) Old 04-19-2014, 06:10 AM
half_crazy's Avatar
I learned a long time ago... no matter what brand of motorcycle you have... almost anything you ask the dealer about, from a vibration/noise to grabby clutch/shifting issue, the answer will be "They all do that".
2006 Victory Kingpin
half_crazy is offline
