Rear speaker harness location? - Victory Forums - Victory Motorcycle Forum
LinkBack Thread Tools
Old 04-23-2014, 02:40 PM Thread Starter
Good-One67's Avatar
Default Raer wiring harness location?
Greetings all. i have 13 XC, and i am planning on expanding the audio system and was just wondering if someone may have info on where factory harness connector is located or hidden. If you have color code for rear speaker wiring that would be great as well. Thanks for your input.
2013 Cross Country, RJC exhaust, Lloyd's Filter, Timing wheel, PCV, Adjustable Rear lowering link, Goody's front lowers. NW New Mexico
Good-One67 is offline
Old 04-23-2014, 02:43 PM Thread Starter
Good-One67's Avatar
Default Rear speaker harness location?
Anyone know where the rear speaker connection harness is hidden? I have a 13 XC not the tour model and am wanting to add some rear sound. If you have color code or schematic for this connection I would be greatly appreciative. Thanks
Old 04-23-2014, 02:56 PM
CrossRoads's Avatar
If I'm not mistaken, the trunk speaker connector is under the left hand side cover. That's what you're after.
CrossRoads is offline
Old 04-23-2014, 04:42 PM
rlaws797's Avatar
I can check for you when I get home.
Houston, TX
2015 XC Suede Black w/ Red Pinstripes
rlaws797 is offline
Old 04-23-2014, 06:36 PM
Encmerk's Avatar
+1 to CrossRoads! It is under left side cover. Others with XC have located it and subsequently added a trunk plus speakers no problems!
Master Sergeant, USMC Retired
2002 HD Sportster 1200 Custom -sold
2013 XCT Boardwalk Blue picked up 1/21/2014
Vance and Hines hi output slip-ons
Lloydz hi-flow air filter
PCV w/AT
Lloydz ATS @ +4
CrossRoads HID's Hi and Low
Havelock, NC
Encmerk is offline
Thread Tools
