Trailer questions - Victory Forums - Victory Motorcycle Forum
post #1 of 20 (permalink) Old 04-28-2014, 09:42 AM Thread Starter
Good-One67's Avatar
Default Trailer questions
Hey gang. Looking into building a tow behind trailer. Have seen alot of mentions for the kit from harbor freight and adding car top enclosure. looks appealing for costs and such and should fit my needs very well. My main questions are doing searches for hitch for bike and seem to be very limited on choices. Can this be built also? Or does someone have a few pics of ones they have on the XC? Just trying to save $ and not be spending on things that can be built. Also what should I be expecting if start pulling trailer with bike? Tire wear? Loading recommendations? Thanks again for all your input. Dave
2013 Cross Country, RJC exhaust, Lloyd's Filter, Timing wheel, PCV, Adjustable Rear lowering link, Goody's front lowers. NW New Mexico
Good-One67 is offline
post #2 of 20 (permalink) Old 04-28-2014, 04:11 PM
rickster's Avatar
I pull 2 different trailers one I bought off E Bay from Americas Best the other is from HF I built to haul our mountain bikes, 12" tire one. Both tow very well and I bought my hitch from BushTec.
2012 Victory Cross Country Tour Pearl White
"You know your in trouble when the drums stop beating"
rickster is offline
post #3 of 20 (permalink) Old 04-28-2014, 04:20 PM
rickster's Avatar
image.jpg Americas Best
rickster is offline
post #4 of 20 (permalink) Old 04-28-2014, 04:25 PM
rickster's Avatar
image.jpg.
Bike Trailer built from the HF 12" tire model I had to buy the diamond plate and used mule car top bike carriers as well.
rickster is offline
post #5 of 20 (permalink) Old 04-28-2014, 04:29 PM
rickster's Avatar
Loaded up behind the XCT
rickster is offline
post #6 of 20 (permalink) Old 04-28-2014, 05:14 PM
I haven't pulled one yet with the XTC working on getting it set up. But I have pulled one with my Venture the same trailer as Ricksters Americas Best for thousands of miles. With any trailer watch your tongue weight when loading you can use a bathroom scale. Try and keep your tongue weight @ 35lbs or less. Anything over that and you may start to feel it in a tight turn or braking hard. Loaded correctly you won't know it is back there except at the gas pump. Again not sure how it will affect the Victory on that someone else will have to chime in. Lots of HF trailers out there and the consensus is they pull great just take your time assembling, repack the wheel bearings, and make sure the tongue length I think is twice the axle width I would have to go back and research that for sure. Basically tongue needs to be longer to prevent any sway. There are swivel balls available but in my opinion that's just extra cost never used one and never had a problem even through the twisties. I bought the Americas best because it looked good and was reasonably priced compared to some m/c trailers. would luv to have a bushtec but I can't justify the cost for no more than I get to use it maybe 3 or 4 times a year. There is also a Piggyback trailer not sure if it is sold by HF but do a search basically the same with car topper but one complete kit some where around $300 to $400.00 just have to do a search and shop around.
PLAYBOY is offline
post #7 of 20 (permalink) Old 04-28-2014, 05:16 PM
Originally Posted by rickster View Post
Attachment 73513 Americas Best
Looking good there Rick
PLAYBOY is offline
post #8 of 20 (permalink) Old 04-28-2014, 05:48 PM
If you buy a harbor freight or some other trailer your best bet would be pull the bearings and go to a bearing store and get high speed bearings. Use good grease on them. Use lock tight and nylock nuts.
post #9 of 20 (permalink) Old 04-28-2014, 06:26 PM
rickster's Avatar
rickster is offline
post #10 of 20 (permalink) Old 04-28-2014, 06:56 PM
dentdave's Avatar
Here our Bushtec , pulls great you don't even know it's back there.
David
www.dentdave.com
2012 Cross Country Tour
IBA # 33520 - 1040 in 24, 04 / 2008
1036 in 24, 10 / 2014
Michelin Primacy Alpin PA3 ZP 195/55/16
dentdave is offline
