Best Combo For Head Buffeting? - Victory Forums - Victory Motorcycle Forum
post #1 of 21 (permalink) Old 05-02-2014, 05:47 AM Thread Starter
JJKJR's Avatar
Default Best Combo For Head Buffeting?
Hey Folks, probably only a few weeks out from purchasing a Havasu Red XC. Took one for a ride yesterday that had only the stock windshield and WOW! The head buffeting was tremendous. So what have you done to minimize it?
I came up with this Klock Werks Tinted medium height (8 1/2in) windshield (2878833-02) and Victory lower wind deflectors (2877896). I also saw these things called Fairing Air Deflectors (2878527). Do you do all three, just two? If this helps, I'm 6' 1" and currently ride a Suzuki Volusia using a National Cycle 2-Up quick detach windscreen with lowers and receive no head buffeting.
Thanks for any recommendations. I can't wait to joint the XC Family. Is there a secret handshake?? Just fooling.
JJKJR is offline
post #2 of 21 (permalink) Old 05-02-2014, 07:17 AM
BigMike45's Avatar
Welcome to the Victory family! I have the Madstad windshield with brackets. I can adjust the windshield up/down and fwd/backwards (angle). I am 6' and my shield is 11" tall. If I don't want buffeting I raise it as high as possible and adjust the angele to 90 degree and I don't get any buffeting and I wear an open face helmet.
I have heard of others with your setup so I'm sure someone will chime in.
2013 Black Victory Cross Country Tour
21" Magnum rim
Arlen Ness beveled shifter
Arlen Ness beveled heel shifter
Arlen Ness beveled brake arm
Arlen Ness shifter/brake pegs
HID High/Low
Lloyds timing wheel
Lloyds air filter
Arlen Ness Big Honkers
Custom Tribal graphics
Madstad shield
USN/LCDR LDO
BigMike45 is offline
post #3 of 21 (permalink) Old 05-02-2014, 07:42 AM
sep1006's Avatar
I am 6'-1" as well and I installed the Gustafson Euroflip Shield at +2" and that eliminated ALMOST all of the buffeting. I then purchased Goody's lowers from Witchdoctor and that ELIMINATED ALL of the buffeting. Only problem for me then there was too much heat coming from the engine and my legs were cooking. I ended up taking the lowers off and will put them back on in the winter time for sure.
Just go to the "search" tab and enter buffeting. You will get pages of responses and then be totally confused. What works for me may not work for you even though we are the same height. Inseam ( mine is 34" ) comes into play as well. If your inseam and height match then you should be able to get the same benefits as someone else with the same exact measurements, I did.
2014 VIC XC PEARL WHITE
STAGE 1 UPGRADE W/K&N FILTER
BLACK TRI-OVAL EXHAUST W/CHROME TIPS
BLACKED OUT LENS'
LOWERING LINK ( DROPPED 2" )
CUSTOM PINSTRIPING
PAINTED OUTER CHIN SPOILERS
GUSTAFSON EUROFLIP +2"[/B]
RICZ LAYDOWN PLATE
DEBADGED AND REFLECTORS REMOVED
O2 SENSORS DISCONNECTED
LLOYDS TIMING WHEEL
SHORTY ANTENNA FROM MINI-COOPER
21"WHEEL KIT FROM WD
BUNCH OF NESS ADD-ONS
sep1006 is offline
post #4 of 21 (permalink) Old 05-02-2014, 08:05 AM
I second the Madstad vote. I am running a 13" Madstad shield on my '14 XC. I do run the full hard lowers and upper air controls found on the tour, and with the stock shorty the buffeting was terrible as well. I also tried the Victory Flip windshield, no go as the buffeting still killed me.
I ran the 11" Madstad for a while, but found I was always running it in the full up position, so I decided to swap out for the 13" and run it slammed all the way down. It looks much better as the gap along the bottom is minimized.
With the Madstad I get no buffeting all the way up to freeway speeds and beyond. You do still get quite a bit of air in the face and around the head, but it is much calmer.
bskouby is offline
post #5 of 21 (permalink) Old 05-02-2014, 10:43 AM Thread Starter
JJKJR's Avatar
Thanks for the info. I quickly looked at the Madstad web site and saw that there three types of Madstad windshields Which type do most of you use and based on their claims does it seem necessary like lowers are even needed?? One more question, the color. I'm thinking dark grey. What do you all recommend?
JJKJR is offline
post #6 of 21 (permalink) Old 05-02-2014, 11:47 AM
Trade in the bike and buy a VET
post #7 of 21 (permalink) Old 05-02-2014, 02:23 PM
joelis's Avatar
I have the 13" in Medium Tint, not dark. I was going to get dark, but glad I didn't, as you do end up looking through the shield at times if it is in the full up position.
Its amazing how well it works. 80 mph and I can where a loose baseball cap, bill forward, with no issues. Sure it doesn't look pretty, but I'm slowly getting used to that issue. As long as its not in the full up position, its not really that bad ugly.
2013 AG XC
- Chrome Tri Ovals Stage 1
- Madstad Shield
- VictoryHID beams
- Kuryakyn Dually Hwy Pegs
- MCC Custom Fork Mount Deflectors
- Chrome Locking Laydown Plate Cover
- Lock & Ride Chrome Passenger Backrest
- Grasshopper Driver Backrest
- Vic Tracker Grips
- more to come...
joelis is offline
post #8 of 21 (permalink) Old 05-02-2014, 02:27 PM
freddyknuckles's Avatar
Follow the recommendations on the Madstad website for which shield. It is based on your height.
As everyone has said, you still get a little turbulence from below. To completely eliminate it you will need lowers. I prefer the ones sold at Witchdoctor, fabricated by a forum member.
freddyknuckles is offline
post #9 of 21 (permalink) Old 05-02-2014, 06:31 PM
Yup, medium tint seem to be the best compromise. There are times you will want to ride with it up, so being able to see through it is necessary. My 11" I had was the full dark tint, and there was no looking through it.
From what I understand the light tint is really light, more of a smoke than anything.
bskouby is offline
post #10 of 21 (permalink) Old 05-02-2014, 06:45 PM
Mokken's Avatar
I'm 6' 3", I run the Klock Werks shield and the lowers from witchdoctor, no buffeting, it's a nice ride with this combo!
http://buywitchdoctors.com/p/2627/vi...-black-sc-585/
2014 Victory XC, Suede Titanium Metallic, http://www.atlanta3gun.com, if your interested in what I do for a fun!
Mokken is offline
