Autotune and Stage 1 Flash - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 05-11-2014, 09:59 AM Thread Starter
Fulltilt1's Avatar
Default Autotune and Stage 1 Flash
I have my Stage 1 parts ready to install. Mufflers and a LLoydz air cleaner. I'm going to use a FI2000 Autotune. Do I still need the stage 1 flash?? Would this make it easier for the Autotune to work??
Fulltilt1 is offline
post #2 of 4 (permalink) Old 05-11-2014, 10:25 AM
saddlebag's Avatar
Depends.
The idea of auto-tune is that it automatically tunes the bike for desired a/f ratios regardless of the underlying base map. So no you don't need a Stage 1 map.
OTOH, if for some reason that device were to fail and you had to ride on a base map with the higher flow filter and pipes, then the Stage 1 map would be closer to correct for those parts than the stock map.
But since Vic only seems to sell the Stage 1 map as a kit with pipes and filter, it really wouldn't make any sense for you.
2011 Cross Roads
saddlebag is offline
post #3 of 4 (permalink) Old 05-11-2014, 11:30 AM
dtmmil's Avatar
is that a cobra unit, if so you should do some research, they dont seem to like vics very well.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #4 of 4 (permalink) Old 05-11-2014, 11:40 AM
Most guy wish they never bought the Cobra unit
