Fuel injector cleaner? - Victory Forums - Victory Motorcycle Forum
LinkBack Thread Tools
Old 05-14-2014, 07:52 AM Thread Starter
Default Fuel injector cleaner?
Did a few searches on the forum, but couldn't find what I was looking for.
Anyone have any thoughts about using a fuel injector cleaner on an XC? You know, that liquid you add to the gas? Good? Bad? Indifferent?
Thanks!
2013 Suede Nuclear Sunset Cross Country
Vicbaggers Tarzanz handlebars
Thrush modded exhaust
Saddlebag rails
Avon grips and Avon shifter pegs
Kuryakyn Liberator highway pegs with stirrups
and much more
See this post for more details.
Wyckedjester is offline
Old 05-14-2014, 08:27 AM
vindex1963's Avatar
Seafoam good.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
Old 05-14-2014, 12:15 PM
If you stop at a popular gas station most all have a cleaner in there gas. My owners book on my bike and three cars don't say anything about needing any FI cleaner. If Vic or any other bike company though it was need they would tell you for sure.
To me its snake oil but if it give you peace of mind do it. Just make sure it will not eat the seal coating on the inside of your tank
Old 05-14-2014, 12:54 PM
Garion12's Avatar
Originally Posted by vindex1963 View Post
Seafoam good.
Yes it is.
2010 Cross Roads
Lloydz Air Filter
Lloydz Slip on Exhaust
Lloydz Timing Wheel 8*
LLoydz VM1-HPT Cams
Lloydz reflesh 6500 rpm
Dyno tuned by KMC 123 hp 121 tq
Garion12 is offline
Old 05-14-2014, 04:13 PM
I fill up on "premium" and as much as I can try to use brand name fuel like Mobil or Shell which have the highest levels of detergents to keep the entire fuel system clean.
Shouldn't ever be any need for extra cleaner.
Old 05-14-2014, 08:53 PM
luvmyride's Avatar
PaiN is probably right that IF you use Top Tier (http://www.toptiergas.com/retailers.html ), premium fuel you shouldn't have a problem. Even if you use Premium octane, you can have poor grade fuel that can cause unwanted buildup. I know this first-hand in my twin turbo Direct Injection car (learned it after it starting running poorly)
Seafoam has helped clean it out (no carbon/soot out the pipes at full throttle, smoother idle) after one tank.
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
Old 05-14-2014, 09:25 PM
Konga63's Avatar
Seafoam is da bomb. Works as advertised.
2007 Ness Jackpot
Konga63 is offline
Old 05-14-2014, 09:46 PM
vindex1963's Avatar
Costco that's interesting I'm a member but never buy the gas.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
Old 05-15-2014, 08:36 AM
Fulltilt1's Avatar
Use StarTron it's formulated to deal with the residues from ethanol most others aren't. You can get it at most autoparts houses and I think Walmart. Clear liquid in a translucent blue bottle.
2014 XC
Stg1 Exhaust
Lloydz Air Cleaner
Lloydz Timing Wheel
Stg 1 ECU Re-Map
Dobeck Gen4 AFR+ Fuel Controller
Cats Removed (necessitated by richening the mixture)
4 Polk Audio MM651UM/Kenwood 300X4 Punch Amp
Fort Worth, TX
Fulltilt1 is offline
Old 05-15-2014, 08:57 AM
wspollack's Avatar
I've been using StarTron for the last couple of years, every few fillups and over the winter, sitting in the tank (as opposed to StaBil in the olden days, and later a winter or two with SeaFoam). It comes in several concentrations, so pay attention to the label when dumping a bit in the tank.
In addition to other places, StarTron is at most WalMarts... in the boating section. I've been to some WalMarts where the staff didn't even know it existed, but that's where it can be found.
I also -- especially for winter storage -- get ethanol-free high-test when convenient. There are several places near me that sell that. If you have a smart phone, there's a free app called Pure Gas that lists those gas stations in your area.
Cheers,
Bill P.
wspollack is offline
Thread Tools
