rear tire alignment - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 05-15-2014, 09:09 PM Thread Starter
worm5932's Avatar
Default rear tire alignment
Is measuring from the rim to the swingarm accurate when aligning the rear tire? My rear tire seems to be cupping on the sides of the tread. I do ride pretty aggressive.
Thanks.
2010 cross roads, Lamborghini Monterey blue
victory fairing with my own audio kit
timing wheel, lloydz filter, atom bomb slip ons
PCV w/ auto tune, VM1 cams, dyno tune by the vic shop, 117HP 119TQ
worm5932 is offline
post #2 of 15 (permalink) Old 05-15-2014, 09:54 PM
vindex1963's Avatar
40 p.s.i. for cupping probably not alignment but..... I try to get the belt to track the center of the pully then give up because it's nearly impossible so just get is as good as you can that's how I align the rear tire.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #3 of 15 (permalink) Old 05-15-2014, 11:17 PM
Tarzan's Avatar
There is a pretty descriptive procedure in the manual to align your rear wheel. It works for me. I would explain it but it will be easier to see the manual. it has some illustrations and and step by step
'14 Ness XC
Tarzan is offline
post #4 of 15 (permalink) Old 05-16-2014, 05:44 AM
handyhoward's Avatar
As Vindex said... cupping is about air pressure not alignment. I have always run a MCT at max psi cold and have never had a cupping problem. One of my riding buddies likes to run at about 5 lbs less than max and always has a cupping problem and spends hours aligning his rear wheel trying to get rid of it... some old dogs are incapable of changing habits and understanding the new technologies.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #5 of 15 (permalink) Old 05-16-2014, 06:01 AM
TNXR's Avatar
My rear tire with 6k miles on it is also cupping pretty bad. I have always kept my pressure at the recommended psi but starting at the end of last season I bumped my pressure up to 43 psi and I hope that will keep it from getting worse.
2011 Cross Roads Sunset Red
TNXR is offline
post #6 of 15 (permalink) Old 05-16-2014, 06:25 AM Thread Starter
worm5932's Avatar
I check the pressure regularly and its always good. Bumped up to 42 psi this season. But still cupped. Maybe I'll just go to the dark side sooner.
worm5932 is offline
post #7 of 15 (permalink) Old 05-16-2014, 06:54 AM
There is the recommended tire pressure as listed in the manual... wrong! is all I can say about that. Maybe they are trying to sell more tires and labor...
Then there is the max psi printed on the side of the tire... that's the one!!! Keep them there cold... check before each ride with a good gauge... it's cheaper than replacing tires all the time. Even if you go darkside, you have to keep check the psi, however the CT is more forgiving.
Once they start to cup... forget about it.
Handy
post #8 of 15 (permalink) Old 05-16-2014, 07:02 AM Thread Starter
worm5932's Avatar
Every vehicle has the manufacturers recommended tire pressure on the Vin tag. Ours is on the left side of the neck.
worm5932 is offline
post #9 of 15 (permalink) Old 05-16-2014, 08:18 AM
Every tire has a max psi cold rating on the tire... that's the one to use. The manufacturers tire pressure on the vin tag is too low for most usage and they know it, but put it there because it's the law and is the "average" psi to protect them against liability. Use the tire's manufacturers guideline.
Handy
post #10 of 15 (permalink) Old 05-16-2014, 08:30 AM Thread Starter
worm5932's Avatar
I've been raises around cars all my life, my dad has worked in a dealership all his life, went to school to be a mechanic, and worked in a dealership for a few years, and I have never heard that. The tires on my truck show a max of 65 and at 40 I can see the center tread ballooning.
I disagree.
worm5932 is offline
