Crossroads rear brake squeaking with only 500miles - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 05-18-2014, 05:14 PM Thread Starter
Jtlos's Avatar
Default Crossroads rear brake squeaking with only 500miles
I only have 500 miles on my new cross country and the rear brake is already squeaking just before I come to a stop. Has anyone else experienced this problem? It's pretty embarrassing. Especially when the Harley guys are laughing...
Jtlos is offline
post #2 of 4 (permalink) Old 05-18-2014, 06:53 PM
Go back to dealer and tell them. Or try applying a little more or less pressure when breaking.
Remember front breaks stops you and rear slow you down.
post #3 of 4 (permalink) Old 05-18-2014, 07:00 PM
Fulltilt1's Avatar
Lubricate the back side (metal that rides against piston) this is where most squeaking and squealing comes from. I usually tape my pads up and spray dri-lube (graphite) on the backside before installing.
2014 XC
Stg1 Exhaust
Lloydz Air Cleaner
Lloydz Timing Wheel
Stg 1 ECU Re-Map
Dobeck Gen4 AFR+ Fuel Controller
Cats Removed (necessitated by richening the mixture)
4 Polk Audio MM651UM/Kenwood 300X4 Punch Amp
Fort Worth, TX
Fulltilt1 is offline
post #4 of 4 (permalink) Old 05-18-2014, 07:14 PM Thread Starter
Jtlos's Avatar
It's going to the dealer on Tuesday for its 500 mile service. I'm going to tell them to fix it then. I shouldn't have to think about how I'm using my brake to keep it from squeaking.
I'm hoping they fix it, I was just worried that since it's so new that maybe I had a pad issue.
Jtlos is offline
