Trickel charger plug location - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 05-22-2014, 04:14 PM Thread Starter
ostbob's Avatar
Default Trickel charger plug location
2012 XCT anyone install the cord/plug for the trickler charger and where and how did you do it.
Bob
Retired law enforcement
Ex-USCG
2012 Victory XCT,
floor board skid plates,
tankslapper 3M paint protection.
Magic Strobe modulationg trunk brake lights
2" pull backs
Russel Day Long seat
Kriss Industries Headlight modulator
Doran tire pressure monitoring system
ostbob is offline
post #2 of 19 (permalink) Old 05-22-2014, 04:22 PM
Bought mine used and it came with one. It is just the Battery Tender pigtail and is installed direct to the battery behind the front cover that hides the battery.
Rob
2012 Victory Cross Country - Imperial Blue
2008 Honda CBR1000RR - Winning Red
2003 Honda VTX 1800C - Illusion Blue
BigBlue is offline
post #3 of 19 (permalink) Old 05-22-2014, 05:04 PM
Bought mine used as well and they zip tied mine by the rear brake reservoir.
2013 xct bronze
VM1 DR-T "Touring" cams
Lloydz air filter
Timing wheel at 5 deg
Quarter turn throttle
D&D's wrapped
Tuned from The Vic Shop 8/14/15
Dyno 123hp 117tq
Led headlight
Digital guard dawg
HMD gorilla bagger bars
Centermatic wheel balancers
Hydraulic clutch
2015 xct black wife's
Leman crossfire trike kit
Quarter turn
Big gonzo mufflers
2 inch pull back bars
Vm1 cams
Air filter
Timing wheel +2
Pcv
Properly tuned by the vic shop on the street
refuse2 is offline
post #4 of 19 (permalink) Old 05-22-2014, 05:06 PM Thread Starter
ostbob's Avatar
Bigblue where did you put yours so you can plug it in. I'm looking for idea's on where the best place is for it to stick out so I can easily get to it and still be out of the way and easy to install.
Bob
Ex-USCG
2012 Victory XCT,
2" pull backs
ostbob is offline
post #5 of 19 (permalink) Old 05-22-2014, 05:39 PM
You might all ready have the plug in down by the battery.
post #6 of 19 (permalink) Old 05-22-2014, 06:41 PM
navycraig's Avatar
My charger came with a pig tail that I wired to the battery and ran the pig tail through the slots of the chin spoiler. Easy access to plug the charger into and at all other times I have a charger cord attached to the pig tail that allows me to plug in my phone or GPS.
Easy stuff.
God Bless America
U.S. Navy Retired
2012 Victory Crossroads Classic L.E. (#258)
PC V and Dyno tuned by Kyle of KMC
Lloydz High Flow Filter
Lloydz Timing Wheel
Lloydz Drop In Cams
Lloydz 1/4 Turn Throttle
Crossroads HID high/low lights
Making 113 HP and 115 TQ
navycraig is offline
post #7 of 19 (permalink) Old 05-22-2014, 07:19 PM
Ran mine to the hole between the crash bar and the spoiler/ battery box. Zip tied it to the crash bar along the bottom side where it's easy to tuck in and hide.
2014 XC in Suede Titanium Metallic.
Stage 1 air filter with the rubber strip removed.
Freedom Performance true duals.
PCV with Dyno tune.
Lloydz VM1-DR cams.
Lloydz ATS.
And some other stuff...
http://i.imgur.com/TFNCqxW.jpg
Smitty79 is offline
post #8 of 19 (permalink) Old 05-22-2014, 09:58 PM
I ran it out the left side from the battery compartment, up along the inside of the frame and zip tied it to the wire loom running up there. It is tucked in while riding and easy to reach when I park in the garage. I chose that side because that was the side where the Battery Tender Jr. hangs down from the plug in the ceiling for the garage door opener.
That way the wire hangs from the ceiling strait down and I never have to step over it. I plug it in just for the heck of it, even though my bike rarely sits for more than two days. I spent the day charging the battery while riding all around southern Utah. This place is awesome.
2013 Cross Country Tour
WmDaniel is offline
post #9 of 19 (permalink) Old 05-22-2014, 11:17 PM
Back in 2010 such a cord was supplied and my dealer installed it so its on the left side, with the SAE plug tucked behind the cowl's lower side panel. It comes out just above the shifter pedal.
post #10 of 19 (permalink) Old 05-23-2014, 01:38 AM
infamous_6969's Avatar
I did the same. I chose the left side because it is the easiest location to reach without large potential of burning my hand.
Bike is sold
infamous_6969 is offline
