Alarm System Recommendations - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 05-23-2014, 06:15 PM Thread Starter
barned01's Avatar
Default Alarm System Recommendations
Hi Guys,
I'm seeking recommendations for an alarm system for my '12 XC. I would appreciate if you would respond with recommendation and reason (experience).
Thanks,
DBarnes
Atlanta, GA
'12 XC: '12 XC: Lloydz VM1-Touring Cams, Adjustable Timing System, Idle Air Valve, Air Filter, 1/4 turn throttle adapter / HOTVIC Debaffled Exhaust / PC-V / Adjustable Lowering Link / KewlHeel shifter / Victory HID / Klock Werks / Infinity Kappa 2-Way 6"x9" speakers (2 pr) and 3-Way 6.5 speakers / Boss Tweeters / Alpine PDX-F6 Amp / Tune Tapper Hidden Antenna / Powerlet outlet / Stebel Horn.
barned01 is offline
post #2 of 9 (permalink) Old 05-23-2014, 09:41 PM
Fulltilt1's Avatar
I just ordered one. Alarm and Immobilizer, whatever that means. Had to laugh at the listings with auto-start. I always pull my clutch in just in case someone jammed it in gear in the lot. I would never trust a manual transmission with auto-start.
2014 XC
Stg1 Exhaust
Lloydz Air Cleaner
Lloydz Timing Wheel
Stg 1 ECU Re-Map
Dobeck Gen4 AFR+ Fuel Controller
Cats Removed (necessitated by richening the mixture)
4 Polk Audio MM651UM/Kenwood 300X4 Punch Amp
Fort Worth, TX
Fulltilt1 is offline
post #3 of 9 (permalink) Old 05-23-2014, 10:02 PM
back in the day my riding buddy had a holster strap to his sissy bar with a tag on it.
You guess where the rest is
no one ever touched his bike
post #4 of 9 (permalink) Old 05-23-2014, 10:35 PM
luvmyride's Avatar
I know others have tried this, and I have considered it myself. I miss the keyless security on my HD...
http://www.digitalguarddawg.com/moto...ition-security
Maybe owners will chime in....
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #5 of 9 (permalink) Old 05-24-2014, 01:39 AM
Krisd's Avatar
The guard dawg is basically an immobiliser with remote and keyless start. It does not have a siren and obviously then no sensor alarms. So if what you want is an alarm then guard dawg will not suffice. Having said that though guard dawg is supposed to be a brilliant product for what it does.
Something like 1/2 of all bike thefts are done by lifting the bike up (with a few dudes) so an immobiliser won't be a deterrent 1/2 the time.
From everything I've read the Scorpio alarm (latest version) with remote key fob inclusive of tamper alert is supposed to be a brilliant alarm. I've researched this thoroughly over 2 years since I've had my hammer. There are also lots of threads where guys have installed a more basic alarm that works really really well too- I suggest you do a search on alarms on here and research some more if you haven't already as there is a lot of threads on it.
2012 Hammer S
Freedom Performance pipes now wrapped, PCV, Loyds air filter, ATS, Loyds Cams and 1/4 Turn Throttle adj, Progressive rear shock
300mm rear and 23" front
Krisd is offline
post #6 of 9 (permalink) Old 05-27-2014, 07:50 PM
TelephoneGuy_CCT_Rider's Avatar
I purchased i900 from Scorpio. Installed it myself. Works great. 246 dollars from there web site.
Suggest you get to know your bike. Why you ask. Because you have to figure out where to put it. Location is very important. Most people I've seen put it under the seat. Not a good idea. Why you ask. Dirt from the road comes up under the seat. No room under the seat and it would get very hot in that location. I would suggest in the faring. The antenna needs to be pointed up last 3 to 6 inches (it a wire). Battery connection is in front behind the front wheel and the blinker wires have to be tapped into. There is a perimeter sensor you can purchase for 35 dollars more. The optional kill/start module should not be installed. My opinion only.
TelephoneGuy_CCT_Rider is offline
post #7 of 9 (permalink) Old 05-27-2014, 08:43 PM Thread Starter
barned01's Avatar
Why should it not be installed?
Atlanta, GA
barned01 is offline
post #8 of 9 (permalink) Old 05-27-2014, 09:01 PM
Do you really think you will caught the person in the act of stealing the bike and hit the kill switch while the person is driving away/cold weather start might be useful in cold climate location but I don't leave mine unattended while running for a second.
post #9 of 9 (permalink) Old 05-28-2014, 08:07 AM
Strike's Avatar
I have a Scorpio SR-i900 with the Perimeter Sensor, Iginition Disable upgrades.
Elliot
Victory Motorcycle Club / SOCAL Freedom Riders Chapter
Southern California Motorcycle Association Member
USN VET 1986-1996
Operations Specialist First Class (SW)
Strike is offline
