Two issues...where to start? - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 05-25-2014, 08:11 PM Thread Starter
ALStensby's Avatar
Default Two issues...where to start?
So I'm having two issues on my XR that just started popping up yesterday. Curious if anyone may know of a common problem related to either. I can pull apart and put back together most anything, but I lack a bit in the diagnostics end of things. 2011 XR, 11K.
First off is a minor "starting" issue. It'll still start, but is acting a bit odd...and I don't fully recall if she'd done this before or not. In the Spring of 2012 I replaced the ignition system with a Digital Guard Dawg RFID. Never had any issues. And I don't know that this will be related. Anyhow, I'll flip the switch to turn the bike on, finish gearing up and then I hit the starter. Sometimes I get a turn or a few...but then it just dies..all the lights, etc. I hit it again and it fires up just fine. Perhaps the battery? Or perhaps nothing at all.
The other issue is a little more concerning. I live in MN and we just hit our first 80+ degree day in eight months...so heat is seldom an issue. But after some longer riding yesterday, I pulled off and let her run for a minute or two while I looked up directions. In that time, the check engine light came on. She's running fine and I'm a mile away so I head over. Light goes away as I get speed, so I'm guessing heat warning. Happens again today. I've ridden in much warmer temps and waited for much longer periods without it coming on so quickly. The oil is about 1200 miles old and the level is good. Just seems that it is heat related but it comes on very quickly. Thoughts?
Thanks in advance for any help!
PS: Only engine mod is Witchdoctor moddified slip ons (not gutted). Have had them since about new. Never any issues. And there's nothing obstructing air flow.
Adam
2011 Victory Cross Roads - His
2014 Indian Chief 'Springfield' - Hers
2013 Honda CB500F
ALStensby is offline
post #2 of 12 (permalink) Old 05-25-2014, 10:23 PM
put a wrench on battery terminals bet there loose
add 1/4" lock washers to each one to keep them tight
post #3 of 12 (permalink) Old 05-26-2014, 04:09 AM
smoke's Avatar
Yep, when issues like these pop up the tighten battery suggestion always is first up AND you never hear any follow-up questions. It must solve most of the problems.
Smoke XC
2013 AntiFreeze Green
D&D exhaust, Gust. Smoke +2 Flip or 7" Dk Smoke shield, Kickers with Rockford Fosgate Amp, Vic Pass. Backrest & lots of extra chrome.
2011 Victory Blue XC - Traded
2007 Honda Blue VTX - Traded
smoke is offline
post #4 of 12 (permalink) Old 05-26-2014, 06:53 AM
I was thinking the same on the battery for the starting "issue".
As for the check engine light, if you added less restrictive mufflers you might be inducing a lean running condition which means hotter exhaust pipes and higher temps.....Maybe now that you're riding in warmer weather it is enough to over heat your engine some.
post #5 of 12 (permalink) Old 05-27-2014, 07:08 AM Thread Starter
ALStensby's Avatar
I'll double check the battery post. Recently did something there so yeah...maybe that's it.
As for the exhaust, I do agree with that. However, I've been running them for at least the last two full riding seasons (about 8,000 miles). And I've ridden in much, much warmer weather without it popping up so quickly.
Adam
2013 Honda CB500F
post #6 of 12 (permalink) Old 05-27-2014, 08:28 AM
soofle616's Avatar
Check the battery posts first as that's a quick and easy solution. If that doesn't solve the issue my bet would be on a low battery. This is a common issue in the aprilia world. Big, high compression v-twin is shut down. Motor happens to stop on a compression stroke. Battery has power but it's getting a bit weak and can't push that big jug through the compression. Voltage dips and everything shuts down. In the time it takes to cycle the key off and on some of that compression has bled off so when you hit the button again the motor spins and the bike starts. 50% of the time this is solved by charging the battery with a tender or other charger. The other 50% the battery is on it's way out and will need to be replaced soon.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #7 of 12 (permalink) Old 05-27-2014, 12:47 PM Thread Starter
ALStensby's Avatar
That was kind of my initial thought. I have a trip around Superior in a month so I think I'll just replace the battery. It's over three years old anyhow.
Adam
2013 Honda CB500F
post #8 of 12 (permalink) Old 05-28-2014, 07:33 AM Thread Starter
ALStensby's Avatar
Didn't get a chance to check the battery last night but sure enough...wouldn't go this morning. Interestingly enough, did anyone know that our gauge shows the battery volts when there's an issue? Took me a second, but it read Lo10.0, then Lo09.9. Kind of cool!
Anyhow...now the probably heat issue.
Adam
2013 Honda CB500F
post #9 of 12 (permalink) Old 05-28-2014, 07:44 AM
vindex1963's Avatar
I ride year around here in Phoenix and with our 110-115 summer temps the heat hasn't been an issue at all so I have to doubt 80 anything could possibly cause any problem.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #10 of 12 (permalink) Old 05-28-2014, 12:49 PM
soofle616's Avatar
If your showing 10v just turning on the key your battery is shot.
2013 Cross Roads LE
