Lose Much Oil If Replacing Only the Oil Filter? - Victory Forums - Victory Motorcycle Forum
post #1 of 17 (permalink) Old 05-29-2014, 07:38 PM Thread Starter
wspollack's Avatar
Default Lose Much Oil If Replacing Only the Oil Filter?
As part of an upcoming project, I'm considering removing the oil filter on my '12 XCT... temporarily (for a few minutes), all by itself, not as part of an oil change, i.e., not draining any oil first via the standard drain plug. And then putting the filter back on.
Sorry to be so ignorant about this, but I have to ask: if I take off the oil filter for a few minutes, will 4+ quarts of oil gush out where the filter screws on? Or will just a little dribble out? (BTW, let's assume that the engine is stone cold.)
And if a huge amount won't pour out, will there be even less if the bike is on the sidestand, or if it's straight up, in a chock? And am I correct that boosting the shock up to its max 70-or-something PSI will make matters better, i.e., slightly tilting the bike toward the front?
Cheers,
Bill P.
wspollack is offline
post #2 of 17 (permalink) Old 05-29-2014, 07:58 PM
blueracer17's Avatar
You will lose what is in the filter and a little bit that is in the system. You can do what you want and not worry about it. Just add back the 8-10 ounces or so of oil back into the sump when you are done.
2004 Kingpin
Mustang Seat, Progressive 465 shock, RPW Thor Exhaust, VFC III, S&S Intake, Ness Fly bars, Kuryakyn ISO Grips and throttle boss, Kuryakyn Silver Bullets, Ness laydown plate bracket, Barnett braided clutch cable....
blueracer17 is offline
post #3 of 17 (permalink) Old 05-29-2014, 08:10 PM
TechnoGeek's Avatar
Default Filter removal
If the Filter is removed the oil will come out reasonably quick.
If you are totally ready and fast.....
"My" guess is that you will loose 1/2 quart.
If you clean around the filter for loose dirt etc. and If you keep a clean drain pan under the filter, you can reclaim most or all of it.
I reject your reality, and submit my own!
2012 Cross Roads, Utopia Drivers Backrest, Victory Passenger Backrest, Tall Windshield, Lowers, Mirror Extenders, 3m Clear Paint Protective film.
TechnoGeek is offline
post #4 of 17 (permalink) Old 05-29-2014, 08:22 PM
You will not lose much oil. Just check oil level and refill when fineshed.
2013 cross country tour stock for now
whiskeydave is offline
post #5 of 17 (permalink) Old 05-29-2014, 08:55 PM Thread Starter
wspollack's Avatar
Thank you all for your replies.
Any thoughts regarding having the bike upright vs. on the sidestand? Probably not make any difference?
Cheers,
Bill P.
post #6 of 17 (permalink) Old 05-29-2014, 09:48 PM
Fulltilt1's Avatar
The bike should be upright with the stick screwed in to get an accurate oil level. Add about a cup and start it. Check for leaks. Let engine sit and oil drain back down. Check oil level add if necessary.
2014 XC
Stg1 Exhaust
Lloydz Air Cleaner
Lloydz Timing Wheel
Stg 1 ECU Re-Map
Dobeck Gen4 AFR+ Fuel Controller
Cats Removed (necessitated by richening the mixture)
4 Polk Audio MM651UM/Kenwood 300X4 Punch Amp
Fort Worth, TX
Fulltilt1 is offline
post #7 of 17 (permalink) Old 05-30-2014, 08:45 AM Thread Starter
wspollack's Avatar
Thanks for the suggestions. I do my own oil changes, so I'm pretty familiar with the process. I just didn't know -- in this special, one-time situation -- whether all/most/some/a-little of the oil would flow out, if I removed only the oil filter for a few minutes.
Cheers,
Bill P.
post #8 of 17 (permalink) Old 05-30-2014, 11:32 AM
If you don't mind me asking, why would you need to remove just the filter? I have seen somewhere where people change their oil filter every 2500 miles and oil and filter every 5,000 miles.
I always do both at the same time no matter what, so I am just curious, thanks.
John (Ma) is offline
post #9 of 17 (permalink) Old 05-30-2014, 11:44 AM
Think about this if your bike is running 50psi for oil pressure. Now that pressure is all so going into the oil filter.
So your going to get a big spray of oil all over the back of the bike the garage floor and your self. You will not be able to shut the bike off fast enough before loosing a bunch of oil.
If your doing this to clean out the passageway pull your plug wire so the bike will turn over but not start.
For the life of me I so not understand why you would run the bike with out a filter. It would not accomplish any thing.
Let us know what happened
post #10 of 17 (permalink) Old 05-30-2014, 12:03 PM
gamewarden's Avatar
VJ
I don't think he is going to start the bike up just take off the filter for some kind of maintenance.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
