what grease should I use on my clutch cable? - Victory Forums - Victory Motorcycle Forum
post #1 of 20 (permalink) Old 05-30-2014, 09:51 PM Thread Starter
worm5932's Avatar
Default what grease should I use on my clutch cable?
Just like it says. I took it apart and all looked good, 6200 mi, but in fiddling with it some grease came off and I want to clean it up and redo it.
What kind of grease should I use that I can get from an auto parts store?
Also, should I get some lube to spray down the cable?
Leaving for the tail of the dragon on Sunday and I just want it to be fine..
2010 cross roads, Lamborghini Monterey blue
victory fairing with my own audio kit
timing wheel, lloydz filter, atom bomb slip ons
PCV w/ auto tune, VM1 cams, dyno tune by the vic shop, 117HP 119TQ
worm5932 is offline
post #2 of 20 (permalink) Old 05-30-2014, 09:58 PM
Luciferiad's Avatar
I used some moly grease I had lying around to grease the ends of mine. On the cross bikes (and I think all the newer Vics) the cables are sheathed and do not need to be internally lubricated.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #3 of 20 (permalink) Old 05-30-2014, 10:52 PM
Ghost_Rider's Avatar
I have heard that lubing down the cable can do more harm than good. Just lube the ends. A lot of people use that white lithium or white lightning grease, I can't remember the exact name of it
2003 V92C
Wrapped RPW Slash pipes
K&N air filter
Stebel Nautilus
Viking saddlebags
16" apes
Ghost_Rider is offline
post #4 of 20 (permalink) Old 05-31-2014, 05:17 AM
TNXR's Avatar
I used some honda molylube I had laying around for my dirtbike.
2011 Cross Roads Sunset Red
TNXR is offline
post #5 of 20 (permalink) Old 05-31-2014, 05:43 AM
navycraig's Avatar
Moly Lube.
Also, here is a good video on adjustment.
https://www.youtube.com/watch?v=k_iS2OutTxw
God Bless America
U.S. Navy Retired
2012 Victory Crossroads Classic L.E. (#258)
PC V and Dyno tuned by Kyle of KMC
Lloydz High Flow Filter
Lloydz Timing Wheel
Lloydz Drop In Cams
Lloydz 1/4 Turn Throttle
Crossroads HID high/low lights
Making 113 HP and 115 TQ
navycraig is offline
post #6 of 20 (permalink) Old 05-31-2014, 06:56 AM
philmonger's Avatar
Grease will do nothing but attract dirt and grit, which can lead to cable failure. I've always run my cables dry, and have never had a problem.
2011 XR Midnight Cherry, Hard Bags, Vic htd grips & seat, Vic medium Windshield, unlocked speedo, Lloydz Air filter, VFC III, Lloydz ATS +4, Vance & Hines slip ons
1993 Vulcan 1500 (sold)
1981 Yamaha Seca 750 (ridden into oblivion)
1977 Honda 550 (sold)
philmonger is offline
post #7 of 20 (permalink) Old 05-31-2014, 09:03 AM
Motorbikerx's Avatar
just clean and lube the ends as per the above vid.
Adjust slack when overnight cold.
not recommended to lube the cable.
I use a Moly camshaft break in lube on mine, every oil change.
Moly grease is probably better.
And I change my oil before its due milage-wise.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 20 (permalink) Old 05-31-2014, 09:07 AM
45caldan's Avatar
What does the manual say about lubing the cable?
Easier to ask here than to run outside and dig the manual out, LOL.
Is it in the maintenance schedule?
45caldan is offline
post #9 of 20 (permalink) Old 05-31-2014, 09:12 AM
read the above posts
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #10 of 20 (permalink) Old 05-31-2014, 09:30 AM
45caldan's Avatar
I did before I asked, no one mentioned what the manual recommends/states.
Sorry to have bothered you, will get off my butt and find the manual....
45caldan is offline
