balt noise? - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 06-08-2014, 06:42 PM Thread Starter
steve18229's Avatar
Default balt noise?
need info. when I start down road 1st gear good, when I go to the rest of the gears a get a noise , I switch to 2nd gear give gas it makes noise in back by belt same to 6th gear, after riding for 1/2 to 45 min seems like belt get hot it stops ? why , any fix,
its a 2013 xct , but everything else on bike is great ,
2013 xct
steve18229 is offline
post #2 of 18 (permalink) Old 06-08-2014, 07:16 PM
I would start with checking for proper belt tension and alignment as described in your owners manual. You don't say if you've replaced the rear tire recently, how many miles, how long it's been making the noise. All that aside, start with the most basic of tension and alignment.
Riding a 2012 Imperial Blue Cross Country
Creek_IP is offline
post #3 of 18 (permalink) Old 06-08-2014, 07:56 PM
its the belt
post #4 of 18 (permalink) Old 06-08-2014, 08:12 PM Thread Starter
steve18229's Avatar
last year didn't make that noise to 4800 mile ,sat in garage but not heated low 20 and 30 degrees , this years started I put on 3000 so far , tension dead on.
2013 xct
post #5 of 18 (permalink) Old 06-08-2014, 08:15 PM Thread Starter
steve18229's Avatar
if its the belt should it be ok ? would it fall under warranty ? if I would have to change is there different type belt out there?
2013 xct
post #6 of 18 (permalink) Old 06-08-2014, 11:46 PM
Turbo Highball's Avatar
If tension is good then buy a little block of bees wax and dress the belt. See if the noise goes away.
Turbo Highball
Somewhere in Alberta Canada
2006 Hammer (sold)
2007 Kingpin (sold)
2008 Victory Vision (sold)
2012 Turbo Highball (sold... couldn't corner deep enough!) (See it here) http://www.youtube.com/user/doglegpro?feature=mhee
2014 15th Anniversary CC Tour #088
2011 Ford SVT Raptor Screw (Traded) (blew the motor on the way home from Az Bike Week)
2012 Dodge 1 ton diesel
2013 Polaris RZR 900XP
2014 Pro RMK 800
Too much power is almost enough.
Turbo Highball is offline
post #7 of 18 (permalink) Old 06-09-2014, 03:03 AM
geekydad's Avatar
I had this persist for several months, during the first 10,000 miles. Belt tightened at the dealer, noise went away for about a month. Used chapstick on the outside of the belt, noise went away for about a month and came back.
Dealer finally got enough complaints that they did some research and found that Polaris was aware of a "bad batch" of rear sprockets (pulleys) and got it replaced under warranty. They did 4 replacements in a week...
If you've had all of the routine maintenance already suggested above, might be worth pursuing.
2013 XCT Sunset Red, Tri-oval Stage 1 Exhaust, Lloydz ATS (+4), Lloyds High-flow Air Filter, Lloydz VFC III, Kicker Speakers, Electric Reverse Kit, Ultimate Seat w/Backrest, Passenger Armrest, Madstad Road Glide, Ness Beveled Gas Cap/Derby/Cam, FOBO TPMS,Centramatics Martinez, GA
geekydad is offline
post #8 of 18 (permalink) Old 06-09-2014, 12:05 PM
Your belt should last a good 80 thousand miles.
They squeak is because there out of alignment or you have a bad pulley.
You can rub any thing on the side of the belt you want but keep in mind your rear break pads are wearing un even
post #9 of 18 (permalink) Old 06-09-2014, 07:42 PM
Netnorske's Avatar
Now that was funny right there....lol. I have dealt with belt noise and it didnt sound like that....haha. I knew that was a turkey call before the end, but that was still good.
As for my own issue...my shop owner/dealer personally set the belt tension and alignment on my 2013 XCT using a sonic meter for tension (something he swears by). He aligned the belt to his satisfaction...and I still had the chirping birds. It's possible the pulley is bad (as per the previous posts), but he told me that the belt chirp is a common complaint on the Vics. He said to get some stuff called HD Poly Oil (yes....an HD product) and dress the belt with it, which I recently did. It comes in a 2 oz. tube and is a light white colored grease that I just used my finger to spread on both edges of the belt. That stopped it cold and I haven't heard a peep from the belt in the last 1000 miles....which makes my Tri-Ovals sound that much better.....
Cheers....Kris O.
2013 Victory Cross-Country Tour
2012 1700 Vulcan Voyager
2008 1600 Vulcan Nomad
"Growing old is mandatory, but growing up is optional"
"You never get a second chance to make a first impression"
Netnorske is offline
post #10 of 18 (permalink) Old 06-09-2014, 08:53 PM Thread Starter
steve18229's Avatar
that video was funny , I look at my wife and said did you do that to? she said she should of thought to that,
I glad you guys are here to help with the great info. I let you know what happens
thank you
2013 xct
