Dain Brake Pedal - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 06-16-2014, 07:59 AM Thread Starter
rickster's Avatar
Default Dain Brake Pedal
Does anyone have the install instructions I seem to have lost mine as to how to install mine Thanks Much
2012 Victory Cross Country Tour Pearl White
"You know your in trouble when the drums stop beating"
rickster is offline
post #2 of 14 (permalink) Old 06-16-2014, 11:36 AM
No knowing what break pedal your installing. It hard to tell you what to do.
Just guessing first step would be is take a vice grip put it on old peg as tight as you can get it and unscrew old one.
From here on in I'm guessing but bolt on new one
Never hear of a "Dain" break pedal
post #3 of 14 (permalink) Old 06-16-2014, 12:46 PM
http://lmgtfy.com/?q=dain+brake+pedal
broggyr is online now
post #4 of 14 (permalink) Old 06-16-2014, 01:31 PM
catroadman's Avatar
I just did mine this past weekend. Vise grips unscrew the peg. Then you will have bolt internal star washer pedal external star washer. Allow the pedal to face down, start the bolt snug it up. I suggest to adjust the pedal angle now than tighten. I carried a wrench to tweak to where I wanted them. How this helps
2011 X-country
catroadman is offline
post #5 of 14 (permalink) Old 06-16-2014, 03:16 PM
Squatch's Avatar
Hey VJ
It is spelled
B R A K E
Squatch
USN/USCG Vet
2013 Cross Country Tour
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
D&D wrapped/RPW baffles
Touring Cams
124 hp/119#ft
A country that forgets it's defenders, will itself soon be forgotten
Squatch is offline
post #6 of 14 (permalink) Old 06-16-2014, 03:59 PM
I wonder if VJ is using some sort of voice diction system...
post #7 of 14 (permalink) Old 06-16-2014, 06:14 PM Thread Starter
rickster's Avatar
Got it thanks
rickster is offline
post #8 of 14 (permalink) Old 06-16-2014, 06:47 PM
He said "DAIN"
post #9 of 14 (permalink) Old 01-26-2015, 04:47 PM
tang56's Avatar
I broke the bolt taking the old one off! Any suggestions. I'm thinking, drill it out and re-tap? Any help would be appreciated.
Professional Big Game Hunter! & Ballroom Dancer! Natural born judge of fine whiskey! Smart enough to NEVER compliment a lady on her mustache! No matter how magnificent!
2014 XCT, stock, with a loud horn!
tang56 is offline
post #10 of 14 (permalink) Old 01-26-2015, 10:22 PM
drill in the middle and then use a easy out
