My 2012 cross country touring project - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 06-18-2014, 05:38 AM Thread Starter
Vicbagger23's Avatar
Default My 2012 cross country touring project
Well here is goes this is my 2012 cross touring. I purchased it new in May 2012. I had D&D mufflers installed and pull back bars installed before I picked it up
Last fall I decided it was time for upgrades. I installed an Arlen ness 23" front wheel, 6degree tripple clamps, fender, fork limiters, front brake rotors, and a new abs ring. Also since I had the front end apart I installed an amp and speakers
I had to splice into the factory harness to install the amp
Cleaned up and taped up
Arlen ness wheel
Vicbagger23 is offline
post #2 of 9 (permalink) Old 06-18-2014, 05:40 AM Thread Starter
post #3 of 9 (permalink) Old 06-18-2014, 06:02 AM
DirtyDan's Avatar
Very nice! Looking good man!
I'll be doing mine here shortly.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #4 of 9 (permalink) Old 06-18-2014, 06:03 AM
Weeds's Avatar
Looks like it turned out good, nice splice job on the wires, heat shrink is a must, , thought you forgot to put the tire on the wheel.
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #5 of 9 (permalink) Old 06-18-2014, 06:44 AM Thread Starter
I'm a Toyota technician so I know my way around a toolbox and soldering wires. I need to disassemble the front forks and put a thicker fluid. Factory oil weight is 5w but I have bottomed out the front end 4 times while braking and driving over a bump. So I'm going to bump it up to 15w fork oil
post #6 of 9 (permalink) Old 06-18-2014, 06:57 PM
x-mann's Avatar
when doing the front wheel, can you use the stock rotors?
x-mann is offline
post #7 of 9 (permalink) Old 06-18-2014, 07:14 PM Thread Starter
Yes but I ordered the matching rotors
post #8 of 9 (permalink) Old 06-19-2014, 04:48 AM
post #9 of 9 (permalink) Old 06-21-2014, 09:18 AM
Very nice! Wheel looks amazing!
2014 XC in Suede Titanium Metallic.
Stage 1 air filter with the rubber strip removed.
Freedom Performance true duals.
PCV with Dyno tune.
Lloydz VM1-DR cams.
Lloydz ATS.
And some other stuff...
http://i.imgur.com/TFNCqxW.jpg
Smitty79 is offline
