Thermometer not correct - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 06-18-2014, 06:48 AM Thread Starter
Vicbagger23's Avatar
Default Thermometer not correct
Since I purchased my bike I have felt that the thermometer is not correct. Does anyone else feel the same way? Is there a fix?
I own a 2012 cross country touring
Vicbagger23 is offline
post #2 of 13 (permalink) Old 06-18-2014, 07:12 AM
Weeds's Avatar
Mine seems fairly accuate, maybe 1 or 2 degrees off..Whats yours..
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #3 of 13 (permalink) Old 06-18-2014, 07:21 AM
wspollack's Avatar
Like Weeds, mine is always about one degree off from the temp displays at local bank signs, etc. 2012 XCT, BTW.
Keep in mind that this will show the heat off the road, not the official weather bureau temp (which is a shade temp). For instance, riding yesterday -- while moving along, not stopped -- my temp gauge got up to 96, while the official high around here was 90, and it was maybe 88 at the time.
Cheers,
Bill P.
wspollack is offline
post #4 of 13 (permalink) Old 06-18-2014, 07:29 AM Thread Starter
Oh that makes sense. I was expecting it to ready outside temp not road temp that explains why it's 5-10 degrees off sometimes
post #5 of 13 (permalink) Old 06-18-2014, 07:37 AM
Weeds's Avatar
Once im rolling down the road it reads close, not 5-10 degrees off..
2013 XCT, Red,
Weeds is offline
post #6 of 13 (permalink) Old 06-18-2014, 07:38 AM
wspollack's Avatar
Yep, if it's cooler out -- and the blacktop, etc., is not acting like a giant heat sink, and radiating that heat back upward big time -- the underneath-the-fairing temp sensor will be closer to the weather-bureau readings.
Cheers,
Bill P.
post #7 of 13 (permalink) Old 06-18-2014, 08:01 AM
Borrec's Avatar
Where the sensor is located will explain delta between free air temp and other temperature numbers you see.
2014 XCT
Atom Bomb Mufflers
PC-V
Lloydz Air Filter
Lloydz ATS
Going to war without France is like going hunting without an accordion. You leave alot of noisy useless baggage behind.
I'd rather go down the river with seven studs than with a hundred ****heads" Colonel Charlie Beckwith.
Borrec is offline
post #8 of 13 (permalink) Old 06-18-2014, 09:46 AM
The temperature sensor is located inside the fairing near the power outlet. Its the little black thing with the ring lug on the end of it. My temperature was always way off. This could have something to do amp being inside of the fairing and building up heat. I moved mine to under the fairing around the neck. It reads pretty accurately now.
2013 Cross Country
Florence, SC
Defender Bob is offline
post #9 of 13 (permalink) Old 06-18-2014, 10:13 AM
Weeds's Avatar
Good info, thanks.........
2013 XCT, Red,
Weeds is offline
post #10 of 13 (permalink) Old 06-18-2014, 10:17 AM
wspollack's Avatar
That's an interesting point. I don't do tunes when I ride. I'm not sure whether that eliminates electricity to the amp -- I have "VICTORY" displayed in the panel -- but it certainly doesn't add any.
Cheers,
Bill P.
