Pass Floorboard Issue - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 06-19-2014, 06:45 AM Thread Starter
tkirby16's Avatar
Exclamation Pass Floorboard Issue
Just info for you that have them. I purchased them when I bought the bike. Dealer put on the right hand side for me. Just didn't wanna do it. After this, I started noticing that the pin holding the actual floorboard on was backing out. I started carrying a hammer knocking it back in until I could get to dealership. I stopped at Sloan's in Murfreesboro, TN. They put a C clip on it. I told the advisor I did not think that was going to work. He reassured me...yea! I went on that Sat ride with my wife, it was fine. I went on a Vet ride on Sunday, got home and floorboard was GONE!! Starter went out the same day. Sloan's covered starter and floorboard after me bitchin about them installing it and bought when bought bike. Got back last Thursday. Looked down Tuesday........Pin was backing out again. I took out and drilled a hole through the end of it and put in a cotter pin. Just a heads up to check your floorboard retaining rings!!!! My right side is holding fine but I'm still going to drill it out. Hope no one else has had this happen.
And when I got my bike back, they had scratched the shit out of my tank. Just a little bit of info for you all in the Nashville area.
Bulk
USN Submarine Veteran
2013 Victory Cross Country
PCV, Bassani Exhaust, HMD Gorilla Bagger Bars, Pass Floorboards, Pass Quick Disconnect Backrest, HID kit, Victory Derby/Cam covers, mirrors, Lloydz Timing Wheel and Lloydz Air Filter, Avon grips and Quarter Turn Throttle ring, RICZ laydown plate!!
Spring Hill, TN
tkirby16 is offline
post #2 of 7 (permalink) Old 06-19-2014, 07:19 AM
wspollack's Avatar
No excuse for the tank. I think I'd demand a new tank, but that's easy for me to say -- I don't have to deal with them.
Regarding the passenger floorboards on XCTs, that has been discussed in a few threads here. I have a picture and a caption discussing this problem and its solutions as part of my gallery, in this particular picture: http://www.billanddot.com/victory-xct/#28
Cheers,
Bill P.
wspollack is offline
post #3 of 7 (permalink) Old 06-19-2014, 12:17 PM
Stand you ground and tell them about your gas tank.
It seams like all floor board pins fall out. I think its cause the pin doesn't have a deep enough grove in it. Or it does before they chrome it and then its gone.
Say take you bike to a auto detailer and ask them to buff it out could be better then new
post #4 of 7 (permalink) Old 06-19-2014, 01:27 PM
Weeds's Avatar
I check mine after each ride, yes they do back out, prolly will do the cotter pin fix as mentioned...
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #5 of 7 (permalink) Old 06-19-2014, 05:14 PM
Here is a trick. You want the flat head of the pin facing forward.
That way if you loose the c clip the pin will not slide out.
post #6 of 7 (permalink) Old 06-23-2014, 08:01 PM
Mine started backing out on the ride home from buying bike. I tried to put an e clip on it but the grooves are to shallow. I contacted dealer to send me clips and they are special spring clips, very easy to install but seems that not all bikes come with them on from factory or dealers are not puting them on when putting bikes together.
2013 cross country tour stock for now
whiskeydave is offline
post #7 of 7 (permalink) Old 06-24-2014, 09:19 AM
irv
irv's Avatar
those clips are small. you hardly know they are there/
mph faster].
irv is offline
