installed lloydz ATS and I think theres an issue - Victory Forums - Victory Motorcycle Forum
post #1 of 45 (permalink) Old 06-25-2014, 05:37 PM Thread Starter
Default installed lloydz ATS and I think theres an issue
Ok fellas, I need some help. I was having issues with excessive popping and bike falling on its face. Brought into vic shop and they messed with mapping and still has issues, so they installed under warranty a lloydz advanced timing gear. I picked up bike and immediately noticed that the bike has a lot more pull, the popping has seemed to lessen and overall runs smoother. So wheres the problem??? Glad you asked! Im am getting an evident ticking type noise coming from the engine, very noticable at idle and under certain acceleration, that I dont recall being there before. Iz this a characteristic of this lloydz ATS kit or did they do something wrong. Other than a vic stage 1 trioval the bike is stock. Any help or thoughts is greatly appreciated.
markaas is offline
post #2 of 45 (permalink) Old 06-25-2014, 05:48 PM
Are you pinging? I would go with higher octane gas and see if that helps but most vics have a tick.
2011 vegas 8ball PCV, swept pipes rpw modified baffles, llyodz vm1-dr cam, ats +4, 1/4 throttle, ud pulley and ness intake.
KMC tuned 114hp/125ft/lbs
shanko is offline
post #3 of 45 (permalink) Old 06-25-2014, 05:58 PM
If it's doing it at idle, it's probably a normal sound. I can almost guarantee you that the Vic Shop wouldn't let a bike out that had an issue. It's valve clatter, it's an overhead valve engine. The cams are up top, not like a Harley, and there is no water jacket like water-cooled bikes to absorb the sound. It's probably normal. You are probably hearing it more now because the engine is running better.
If in doubt, post a short video of what you are talking about and post it.
post #4 of 45 (permalink) Old 06-25-2014, 06:03 PM
Weeds's Avatar
Take it back and ask them....
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #5 of 45 (permalink) Old 06-25-2014, 06:05 PM
Agreed. If it concerns you, ask them. They'll tell you straight up.
post #6 of 45 (permalink) Old 06-25-2014, 06:13 PM
Weeds's Avatar
Surprised a dealer would go as far as to put a wheel in, I doubt the few around me would, hopefully they'll help you out...
2013 XCT, Red,
Weeds is offline
post #7 of 45 (permalink) Old 06-25-2014, 06:20 PM
Not only that, they did it 'under warranty'!
post #8 of 45 (permalink) Old 06-25-2014, 06:24 PM
Vicbuilder's Avatar
I think he meant that he brought it to A Vic Shop, not THE Vic Shop!
That being said the timing wheel should not cause any noise. What a lot of people don't realize though is that it will lean a bike out. That's why you hear a bunch of people raving about improved mileage after the install. So take a bike that is super lean to begin with, then lean it out another 1/2 a point....things can happen.......
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
post #9 of 45 (permalink) Old 06-25-2014, 06:41 PM
If in doubt, I can come listen. That would be a nice ride for me.
post #10 of 45 (permalink) Old 06-25-2014, 06:45 PM
These engines have hydraulic lifters and the ticking sound could be them due to older oil that has lost enough viscosity and/or wrong oil weight. If it only does it at idle and not when traveling, I wouldn't worry about it, but if the oil is older, I'd change it.
RICZ is online now
