Help with Lloyd's time ing wheel !!! - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 06-27-2014, 10:00 AM Thread Starter
Default Help with Lloyd's time ing wheel !!!
Hey gang I am having trouble getting the new timing wheel in. It does not slide in wheel at all. The old one was hard coming out. Anyone have any suggestions ? I am stuck.
Jim
JPokerwinski is offline
post #2 of 15 (permalink) Old 06-27-2014, 10:06 AM
Don't force it. It should just slide into place with a little wiggling. Does it not fit in at all? Check to make sure the key on the shaft isn't broken or anything.
post #3 of 15 (permalink) Old 06-27-2014, 10:07 AM Thread Starter
I got it. Cleaned off everything and a little wd40
post #4 of 15 (permalink) Old 06-27-2014, 10:19 AM
BP6666VR's Avatar
WD40 is NOT a lubricant, next guys who have trouble, just dip your finger in a Vic engine oil, new or from the dipstick and use that one.....
it will go much better....
Cross Country Tour 2014 [B]
BP6666VR is offline
post #5 of 15 (permalink) Old 06-27-2014, 10:35 AM
There is a key slot on the new wheel and old wheel measure them to see if there both the same.
If not call Lloydz DO NOT FORCE IT ON
http://cyrilhuzeblog.com/2014/06/26/...ports-complex/
post #6 of 15 (permalink) Old 06-27-2014, 10:36 AM
Jim
the wheel is for 2008 and up and you need to say whay year and model you have
post #7 of 15 (permalink) Old 06-27-2014, 11:08 AM Thread Starter
Ok done. A little engine oil and some wiggling and it went in. But one of the cover bolt just sheared in half and I just slightly tightened it. Of course the local dealer said he had to order the bolt. Wtf. A common bolt. So northwest hard had a. Great election of metric stuff.
post #8 of 15 (permalink) Old 06-27-2014, 11:39 AM Thread Starter
I did call Lloyd's and some chick answered and said she could help me when I told her I couldn't get the new one on. So it old her it seem to be having problems sliding on easy. She told me to refer to my service manual. WTF ! My first encounter with tech support at Lloyd's and I am told to refer to my service manual. Why did she just say take two aspirin and call me in the morning! Anyway. It went on after some cleaning around the shaft and some oil.
post #9 of 15 (permalink) Old 06-27-2014, 11:47 AM
Take one of the good bolts go to hardware store and get one from them
post #10 of 15 (permalink) Old 06-27-2014, 11:56 AM
I would do this first. It may not match exactly, so you can put it at the bottom where it's hidden by the floorboard
