Easy exhaust mod for better sound - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 48 (permalink) Old 06-28-2014, 08:33 PM Thread Starter
Default Easy exhaust mod for better sound
Like most of us I've been wanting better exhaust sound out of my stock XC(damn, I wanted it to sound like a big V-twin should....) but have been hard pressed to come up with enough play money to fund a new exhaust or even mufflers. Also I am under strict orders from my wife not to make the Vic as loud and annoying as my HD was... I have been pouring over the threads on DIY exhaust mods and de-baffling but do not have the tools or skills to tackle that job correctly. Last night I had a brainstorm while looking at a pic of a gutted XC baffle...Essentially the end plate(or entire baffle) is being removed to un-restrict the exhaust flow. I reasoned that opening up the end-plate would have the same effect and could actually be tuned to a desired sound level by how many holes were punched in it. This morning I took the bags and end caps off, then started drilling the end-plate. I'd punch a few holes, start the bike and listen. Even after the first few holes I could tell I was on track.....it was sounding right. I drilled more and opened the holes, until I was satisfied with the sound. I hit the ends with some high heat black to prevent rust from starting, then put the caps back on.
I rode it for about 150 miles and wow! too me the new sound completely changes the personality of the XC. Its got a nice idle thump, a great decel. rumble and growls more than ever under throttle....best of all there is no "drone sound" at speed, I can still clearly hear the radio and wind. The wife should be happy....
This is very simple to do, the mufflers do not even have to be removed from the bike. The only tools needed are a power drill, various bit sizes and a 10mm wrench or socket.
Here are some pics at the start and painted finish. Hopefully, the vids will post(although they do no justice to the real world sound). First is the stock pipes then completed with the caps on.
Vids:
stock
http://s181.photobucket.com/user/Mik...80003.mp4.html
modded
http://s181.photobucket.com/user/Mik...80014.mp4.html
**As for tuning, I have no comment on how or if this mod will effect a stock tuned bike, I have a Cobra Fi2000 PowrPro installed with the air dam out, after a few miles everything seemed to settle in and it pulls like a bear. Can't wait to change over to a high flow air filter.
post #2 of 48 (permalink) Old 06-28-2014, 08:36 PM
Motorbikerx's Avatar
looks like you've nailed it!..........errr I mean drilled
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 48 (permalink) Old 06-28-2014, 08:55 PM
I have a set of pipes where I essentially did the same thing.
Now, I've cut them apart and removed the inner tubes and plates. I was going to stuff Thrush glasspacks in there, but I was wondering about just welding the end caps back on without the glasspacks. I didn't cut off the outlet pipe or anything and would wonder what this sounds like. I just need a welder!
Sent from Motorcycle.com App
post #4 of 48 (permalink) Old 06-28-2014, 09:14 PM Thread Starter
I'm not sure what sound you're after.....I wouldn't qualify this mod as making the Vic "loud", it is not at all. The modded sound is much better in my opinion, I am very happy to now sound like a V-Twin not a sewing machine.
If you want to hear it, I'm meeting some friends for an afternoon ride tomorrow(Sunday) ~12:30 at the Double Tree Hotel in Bristol, you're welcome to come.
post #5 of 48 (permalink) Old 06-28-2014, 09:16 PM
Yea, I'm definitely not after "loud".
Thanks for the invite, but I won't be able to make it.
post #6 of 48 (permalink) Old 06-28-2014, 09:50 PM
Longbow3's Avatar
I have a question. I'm assuming my mufflers are OEM, they don't have any baffles in the tubes, I can see straight thru. Is this correct? They aren't loud at all. Purchased the bike used so I don't know what if anything has been done other than what I've modded. Thanks in advance..
2011 Blue Cross Country,
VictoryHID.com HID
1" lowered with Witchdoctor link
Grasshopper driver backrest
2007 Vstar 1100 Silverado (traded)
Longbow3 is offline
post #7 of 48 (permalink) Old 06-28-2014, 10:23 PM
There aren't any screen-type or spiral-type baffles in CrossCountry mufflers. The gasses are routed around and through a series of tubes before exiting.
post #8 of 48 (permalink) Old 06-29-2014, 07:26 AM Thread Starter
Here's a pic of the XC baffling. The end plate has been cut and the baffle slid out. This is the pic that gave me the brainstorm to drill the end to plate. With holes in the end plate the exhaust can flow more freely out instead of being recirculated and baffled inside the muffler. Worked like a charm
post #9 of 48 (permalink) Old 06-29-2014, 09:35 AM
Longbow3's Avatar
So, what are my mufflers? Mine have a single tube all the way from the front to the back with perfs. They don't seem to have any baffling or a series of tubes.
VictoryHID.com HID
Longbow3 is offline
post #10 of 48 (permalink) Old 06-29-2014, 10:23 AM
Bujee1's Avatar
Do you still have the stock tips? Wouldn't the heat cause them to turn blue?
2011 Victory Cross Country (for the wife and me)
2012 Victory Highball (for me!)
Bujee1 is offline
