Where to order new brake/clutch cables? - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 07-01-2014, 06:29 PM Thread Starter
Default Where to order new brake/clutch cables?
Hello all! I've begun the great modification adventure and just put new handlebars on my bike. Unfortunately, it appears I need about 6 more inches (ok, keep those snide remarks to yerselves) on my clutch/brake cables. Can someone point me in the direction of a reputable place to order extended cables? Thanks!!
P.S. Just added Vicbaggers Tarzanz bars. Can't wait to test em out!
2013 Suede Nuclear Sunset Cross Country
Vicbaggers Tarzanz handlebars
Thrush modded exhaust
Saddlebag rails
Avon grips and Avon shifter pegs
Kuryakyn Liberator highway pegs with stirrups
and much more
See this post for more details.
Wyckedjester is offline
post #2 of 12 (permalink) Old 07-01-2014, 10:22 PM
witchdoctor make sure you hve enough length.
Measure twice and order once
post #3 of 12 (permalink) Old 07-02-2014, 06:30 AM Thread Starter
Thanks for the heads up! Looked on their site and it appears they only carry stainless steel rather than the black vinyl, which is what I need. I used their contact form and asked if they carried the black vinyl so I guess we'll see.
Saddlebag rails
and much more
post #4 of 12 (permalink) Old 07-02-2014, 07:10 AM
soofle616's Avatar
Motion Pro. I've used them many times in the past to get custom lengths or to simply replace a cable on something too old to get a OE replacement. They usually have a couple options in terms of ordering process. You can tell them your year/make/model and then specify additional length or you can send them your old cable along with instructions for what you want the new one to be relative to that one.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #5 of 12 (permalink) Old 07-02-2014, 10:57 AM
ptc
ptc's Avatar
Brake Cable????? who uses drum brakes anymore???
Im sure you meant brake hydraulic line - you should be able to get one at any speed shop but they are metric.
To find sizes that may fit your application try Earls:
http://www.holley.com/types/Speed-Flex%20Lines.asp
2011 Custom "Hammered XR"
http://streetbikeusa.blogspot.com/
BBob- "We all share the same wind regardless of the t-shirts we wear"
ptc is offline
post #6 of 12 (permalink) Old 07-02-2014, 11:57 AM
luvmyride's Avatar
What pull did you get on the bars? I got Tarzanz +2 and my stock cables fit fine. There is a good bit of slack available.
BTW, 2013 XC as well
You'll LOVE the bars!
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #7 of 12 (permalink) Old 07-02-2014, 12:30 PM Thread Starter
I got +2 back and +2 up. It's definitely too far for the stock to reach, unfortunately.
Saddlebag rails
and much more
post #8 of 12 (permalink) Old 07-02-2014, 01:41 PM
soofle616's Avatar
Hah, didn't even notice that. For hydraulic custom stuff i usually use galfer or goodridge but there are others. Bikebandit carries some build it yourself custom brake lines. Basically buy the line in whatever length you need (based on available lengths) then buy the appropriate bend fittings. Screw it all together and you're done. Did this with the girlfriend's 83 shadow resto and they worked great, no leaks or issues with bleeding. The instructions call out a pretty low torque value for the build but I don't have any crows feet so i just snugged them up and gave them another 1/8 turn or so.
2013 Cross Roads LE
post #9 of 12 (permalink) Old 07-02-2014, 03:06 PM Thread Starter
Very funny! I should have caught that too! :-)
Thanks for the info!
Saddlebag rails
and much more
post #10 of 12 (permalink) Old 07-02-2014, 07:20 PM
ByteN2it's Avatar
I'll share my source for all my bikes cables & brake lines over the years-high quality, made in the USA
http://www.barnettclutches.com/cables.html
ByteN2it is offline
