Help out a former HD guy w/jack placement - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 07-02-2014, 07:24 AM Thread Starter
hmor535's Avatar
Default Help out a former HD guy w/jack placement
Hi all...I have a craftsman atv/motorcycle jack that I've had my HD on many times over the years w/o a problem.
Now I want/need to get my CCT on it by myself. Does anyone have any suggestions or pictures of theirs on a jack?
I thought I would ask first before I try to do it.
Thanks,
Harry
hmor535 is offline
post #2 of 13 (permalink) Old 07-02-2014, 07:56 AM
Do you have the black/red jack or the silver/yellow? I have the silver/yellow and I place the rear lift plate just in front of the oil filter so it lifts via the engine...
post #3 of 13 (permalink) Old 07-02-2014, 08:12 AM
wesdalton's Avatar
Sears Red works well
2010 X C
wesdalton is offline
post #4 of 13 (permalink) Old 07-02-2014, 08:39 AM Thread Starter
hmor535's Avatar
Thanks!
broggyr...... it's the black & red.
wesdalton.....is that a center stand I see under your bike?
hmor535 is offline
post #5 of 13 (permalink) Old 07-02-2014, 09:08 AM
depot picker's Avatar
That looks way front heavy. I'd be afraid to remove the bags, trunk or rear wheel.
depot picker is offline
post #6 of 13 (permalink) Old 07-02-2014, 10:14 AM
I usually put the jack there to lift the rear. You can move it a little forward to lift the front. Experiment. You really can't hurt much unless you put it right on the oil filter.
Sent from Motorcycle.com App
post #7 of 13 (permalink) Old 07-02-2014, 10:51 AM
wesdalton's Avatar
Not at all, I have had the bags and tire off when I replace the tires. No problem at all.
2010 X C
post #8 of 13 (permalink) Old 07-02-2014, 12:25 PM
Glad I looked in here..... I have my Sears red jack modified for the HD DynaGlides(lift pads moved to the outside of the lift arms 1"). I was wondering how it would work if I ever had the need to lift my XC.
Should be no problem at all.
post #9 of 13 (permalink) Old 07-02-2014, 06:18 PM
roadglider's Avatar
you probably should strap front and back to the stand just to be sure.
ffwd to 3:30
roadglider is offline
post #10 of 13 (permalink) Old 07-02-2014, 06:37 PM
wesdalton's Avatar
Originally Posted by hmor535 View Post
Thanks!
Yes, I purchased right after I got the bike. It isn't the Victory brand, I have been very happy with it. Takes up less room in the garage, and makes it much easier to clean and check the oil.
2010 X C
