Running throttle cable through handle bars. - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 07-04-2014, 12:18 PM Thread Starter
Default Running throttle cable through handle bars.
So, have yet another question. I'm trying to run the throttle cables through my handlebars and the slot at the top of the handle bars will not allow the plastic pieces at the top end of the throttle cables to go through. So, I need to remove those pieces in order to thread the throttle cables. Unfortunately, it appears the only way I can get those plastic pieces off is to cut the little barrel end off the end of the cable.
So, my question is, can I cut that end off and then safely add another one onto to the end after I've threaded the throttle cables through? If so, how would I do that? Is there a tool to use? If so, where would I get such a tool and where would I get the barrel ends?
As always, thanks for the pointers.
Pic attached of what I'm referring to.
2013 Suede Nuclear Sunset Cross Country
Vicbaggers Tarzanz handlebars
Thrush modded exhaust
Saddlebag rails
Avon grips and Avon shifter pegs
Kuryakyn Liberator highway pegs with stirrups
and much more
See this post for more details.
Wyckedjester is offline
post #2 of 8 (permalink) Old 07-04-2014, 06:31 PM
STOP its not going to work. NO Way will stock cables work or throttle
you need a kit like this http://www.jpcycles.com/product/5000033#!
and you use panio wires for cables cause they don't flex
post #3 of 8 (permalink) Old 07-04-2014, 06:35 PM
luvmyride's Avatar
Unless it's a full on custom I don't ever see throttle cables ran in bars. HDs run many of their cable in-bar, but not throttle cables. Having the switch wiring (turn sigs, cruise, audio, cruise etc) in the bars would clean it up nicely. Clutch, brake, throttle in bar would be a massive PITA (if even possible)
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #4 of 8 (permalink) Old 07-05-2014, 06:17 PM Thread Starter
Wow, and I thought this was going to be easy. Seems like a waste just to run electrical through the handlebars. I figured everything would go through there. Sounds like doing it that way is pretty damn complicated. Anyone else have any thoughts on the matter?
Saddlebag rails
and much more
post #5 of 8 (permalink) Old 07-05-2014, 08:17 PM
Look at it this way..... Most custom builds that have internal throttle cables have minimal electrical on the switch housings. You have a XC and a LOT of wires coming from the switch housings. If you start trying to run wires and cables inside, I suspect reliability issues will arise. Look at some of the pics around where folks ran the wires inside and put on the nice stainless cables and brake hose. It has a real clean look to it.
Riding a 2012 Imperial Blue Cross Country
Creek_IP is offline
post #6 of 8 (permalink) Old 07-07-2014, 01:40 AM
Speeddemon3579's Avatar
Water supply tubing from ice maker in handle bar first. Switch to internal throttle at the end of handlebar (same could be done to clutch theoretically). Single throttle cable instead of double. Spring the throttle body for return. Run piano wire through tube. Just a thought.... Good luck with custom.
2000 V92SC
Rock Island,TN
If I can't buy it, I make it.
Just Getting Started
Speeddemon3579 is offline
post #7 of 8 (permalink) Old 07-07-2014, 01:51 AM
ragtopdodge's Avatar
http://www.exilecycles.com/index.php?section=37
2005 Hammer
Slash-Ness exhaust
LED teardrops mirrors
LA Choppers dragster handlebars/3" custom risers
Ness intake
Accutronix forward controls
Fat chrome fork tube covers
Ness Rad III levers/master cylinder
Ness pegs
MBW F&R LEDs
Avon heated grips
Dakota digital oval speedo/tach
Bullet OEM Victory LED headlight
Lloyds 1/4 turn
Judge side covers
http://i.imgur.com/oKghkvj.jpg
ragtopdodge is offline
post #8 of 8 (permalink) Old 07-07-2014, 05:17 AM
DirtyDan's Avatar
It'll would RK it's just not that easy. There are a number of internal throttle kits out there on the market. They usually eliminate the return cable, if there is one on a Vic. Newer HD's have throttle by wire so it makes it much easier.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
