Stage 1 flash detection? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 07-11-2014, 11:39 AM Thread Starter
Default Stage 1 flash detection?
XC Stage 1 flash before I fork out $200 for something I might already have (have a new to me 2011 XC Ness with high flow AF & Victory 210 slip ons) is there any way to tell if she already has the stage 1 ECM flash for aftermarket pipes?
Dez
Winnipeg, MB, Canada
2011 Ness XC #46 - Lloydz HF air filter, IAV, timing wheel, and 1/4 turn throttle; Vic. 210 performance pipes; PCV w/Autotune; and removable passenger backrest.
2002 HD Road King (Firefighter edition) - Big bore kit; HD clutch; Ness "Big Sucker"; PC III (dyno'd & mapped); Mustang seat; and removable windshild & back rest w/custom luggage rack.
2003 Vic. Classic Cruiser (Wifes ride) - Shotgun pipes; reach back bars; Mustang seat; removable windshield; and backrest.
firefighterdez is offline
post #2 of 6 (permalink) Old 07-11-2014, 12:25 PM
luvmyride's Avatar
Looking at your Sig, it shows you have a PCV. If that is the case, there is no need for a flash (Stage 1 or otherwise).
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #3 of 6 (permalink) Old 07-11-2014, 01:57 PM Thread Starter
Default Stage 1
Correct XC has the Lloyds AF, Lloyds IAC valve, PCV w/autotune. Dealer I bought it from told me it was Stage 1, and it has the Vic 210 slip-ons. I downloaded the closest config map from the Powercommander website.
Local dealer has suggested I flash the ECM, for $200.
Dynojet said:
"Popping on decel is very common on Vtwin applications with open exhaust. Sometimes you can tune it out and others not so much. On this bike the ECU shuts the injectors completely off on decel so no matter what you do with the PCV it will not effect it. "
I am soon going to installing the Lloyds timing wheel & 1/4 throttle ring.
I hope to try and reduce or remove the popping & backfiring on decel.
Dez
post #4 of 6 (permalink) Old 07-11-2014, 02:08 PM
Get a hold of Rylan at The Vic Shop he will send you a map that will be a good strting poing. Tell him all the information and the ATS
post #5 of 6 (permalink) Old 07-11-2014, 05:34 PM
Weeds's Avatar
With all the calls he gets, how does he get anything done... geezzzz..
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #6 of 6 (permalink) Old 07-11-2014, 09:36 PM
You have not watch him work it took him 5 min to put cams on a cc on his web site video.
2014 XCT15 th Anniversary Limited #077 D&D's
Midnight Cherry 2009 Vision Victory Stage 1 mufflers traded off
(XCT totoled on dragon tail 8-10-14)
Black 2012 Cross Country Tour that now has 14000 miles. 195/55-R16 Rear, Stone 709 on front.
PCV, Autotune, D&D's /Lloydz's air filter.
strip removed. Added CB 7/27/14 it works! LOL
2005 Yellow Goldwing Motor Trike Sold.
93 GL1500 red
Moto Guzzi's for years 71 750 Ambassador fairing and bags. 79 1000 G5 with fairing, saddle bags and trunk.
GrogAV is offline
