1rst gear engagement - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 07-13-2014, 01:45 PM Thread Starter
Default 1rst gear engagement
Hey guy's quick question,
I have 15000 trouble free miles on my 2011 XC and have noticed that sometime the bike goes into 1rst smoothly and quietly and others a very harsh bang which seems loader that normal.
I just replaced the shifter bushing as it was raining today and everything is free of binding and clutch adjustment looks fine. has been this way for a while and don't really remember if it was like that when new.
Any thoughts?
chapster is offline
post #2 of 9 (permalink) Old 07-13-2014, 02:03 PM
Default 20K- BANG still
Got a little over 20,000 miles and still with clutch adjusted correctly it will be smooth and fairly quite sometimes. Other times when knocked into first from neutral it will BANG loudly. Seems normal on these big twins, made in the US anyways. I do not know how the made in Japen big twins do. Just changed my oil yesterday and today it seems better and smoother, seems that way at first after every oil change on my bike.
Buckeye, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. MRA windshield, Rotated front fender forward,relocated ignition switch, Bad Ace Fuel Tank Risers, Fat front tire.
Speedblue is offline
post #3 of 9 (permalink) Old 07-13-2014, 02:06 PM
The harsh clunk is normal. Have you lubed your him ends on the shifter rod and your shifter pedal arm. Have you lubed the clutch pivot housing up on the bars.
We have the same rash clunk as harley its part of the big shifter drum we have
post #4 of 9 (permalink) Old 07-13-2014, 02:12 PM Thread Starter
You bet, all lube completed when I replaced shifter bushings.
Thanks for the reassurance.
chapster is offline
post #5 of 9 (permalink) Old 07-13-2014, 02:49 PM
Luciferiad's Avatar
15k on my XR and it's like kicking a box of wrenches. Always has been.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #6 of 9 (permalink) Old 07-13-2014, 07:47 PM
TNXR's Avatar
Nearly 7k on mine and same thing, sometimes smooth and sometimes sounds like it going to blow apart. Today when going down to 2nd it double shifted on me and went straight to first, never done that before.
2011 Cross Roads Sunset Red
TNXR is offline
post #7 of 9 (permalink) Old 07-13-2014, 09:18 PM Thread Starter
Glad to hear it is normal so i can focus on getting my next toy's for the bike.
2011 Victory XC, D & D pipes, Victory air filter, Stage one map, Ness Mirrors, Klockwerks windshield, Cee Flectors
chapster is offline
post #8 of 9 (permalink) Old 07-13-2014, 10:05 PM
BP6666VR's Avatar
+1
Cross Country Tour 2014 [B]
BP6666VR is offline
post #9 of 9 (permalink) Old 07-14-2014, 04:37 AM
This sounds normal to me. I also have a Honda VTX and when i pop it in first from nuetral if makes a louder than normal clank. in fact i have come to expect this. When my XCT did the same thing i didnt pay it much mind.
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
