Some Instrument lights come on when using Stebel Horn - Victory Forums - Victory Motorcycle Forum
post #1 of 66 (permalink) Old 07-14-2014, 08:44 AM Thread Starter
MrXC2014's Avatar
Default Some Instrument lights come on when using Stebel Horn
I'm having this problem when using my Stebel horn. When I use the horn my flasher indicator and cruise control lights on the instrument panel briefly light up when pressing the horn button?? My wiring connection listed below:
30 = (+) Stebel horn red wire
87 = (+) batt pwr
86 = (-) grey wire old horn
85 = (+) blk wire old horn
BATT NEG = (-) Stebel horn blk wire
2014 Victory CC, Two-Tone, VM1-HPT-DR, PC5, ATS+4, Llyodz HI-FLOW A/F, 1/4 Turn Throttle Ring, Tuned by Kyle Crandall of KMC PowerSports, Flashed ECM, 121hp 113tq
Suede Supersteel & Black, Madison, AL
MrXC2014 is offline
post #2 of 66 (permalink) Old 07-14-2014, 09:07 AM
I wonder if the compressor motor is too much draw for that circuit. I probably would have run a relay; horn button activates the relay, and relay activates the horn. Less draw on the built-in horn circuit.
post #3 of 66 (permalink) Old 07-14-2014, 09:33 AM Thread Starter
MrXC2014's Avatar
I used this wiring harness with 30amp fuse.
So it's drawing directly from the BATT.
MrXC2014 is offline
post #4 of 66 (permalink) Old 07-14-2014, 09:48 AM
This is a common problem when installing the stebel, wolo, or similar. Lots of threads here and on the V M C.
Seems that following the install directions, relay or not, there is feedback across the horn activation switch back into the circuit. Long presses will pop the 10a fuse and you will lose turn signals, cruise, and horn.
Many different attempts to solve it, including an isolated circuit with an external switch other than the oem one, but that is a fugly solution.
I tried different relays of varying quality with no joy. Kevin Cross made a suggestion of replacing the 10a with a 15a and just carry on. I suppose as long as you only use the horn for short blasts this is a workable solution.
No, I have not tested every possible combination of turns, hazards, cruise, and horn. I have heard of some disengaging the cruise by using the horn, but I have to wonder why that particular scenario occurs.
Bottom line, live with it or change it. I have mine this way for 2+ years with no damage.
Others have opted for the Framm Freeway Blaster mounted in the original position using the original circuit with no external battery connection.
Good Luck.
Every day is a good day to ride. Some days are just better than others.
2010 Cross Country
Vic Performance filter, D&D, ATW, VFC III
2006 Vegas (sold)
2003 Shadow 1100C (sold)
Various other bikes all the way back to 1968.
BCVR LC#35
rocketo is offline
post #5 of 66 (permalink) Old 07-14-2014, 09:58 AM
Goatlocker95's Avatar
He is running a relay, the numbers represent the posts on the relay that comes with a Stebel horn.
87 = (+) batt pwr
2014 Indian Chieftain
Goatlocker95 is offline
post #6 of 66 (permalink) Old 07-14-2014, 11:15 AM
Yep, you're right. My bad.
post #7 of 66 (permalink) Old 07-14-2014, 11:42 AM
i have the wolo bad boy and i have no problems at all. if you tap into an exisiting circuit, yea you will pull the circuit down. my relay is switched off the stock horn wires. take the two wires off the horn, connect them to the relay coil ( small current drain). the power to the horn is then taken directly to the battery via the of contacts, through a inline 20A fuse. the negative terminal of the horn wired directly to the battery. again, i have no problems at all and i have used it a LOT
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
post #8 of 66 (permalink) Old 07-14-2014, 11:45 AM
another thing to try. hook the relay up and just the relay. press the horn button and make sure you can hear the relay click (being energized)
USMC - Vietnam
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
1" tank risers
O2 unplugged
1/4 turn ring
post #9 of 66 (permalink) Old 07-14-2014, 11:49 AM
one thing i did notice in the wireing diagram for the vic. I am not sure WHY they ever wired a switch like that. their Engineer must not have passed EET 101. but i still dont see how feedback from the relay(switch) can cause this. the relay uses less current than the original horn. I think there is something else. just fyi.
USMC - Vietnam
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
1" tank risers
O2 unplugged
1/4 turn ring
post #10 of 66 (permalink) Old 07-14-2014, 12:16 PM
gamewarden's Avatar
I installed a Wolo 2 years ago with relay to battery and get the same feedback. Works well in any event and I don't worry about it anymore. I think Victory has some quirky wiring at times.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
