Ignition key relocation bracket! - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By OkieHoss
post #1 of 4 (permalink) Old 03-24-2012, 12:10 PM Thread Starter
OkieHoss's Avatar
Default Ignition key relocation bracket!
wanted to give you guys a heads up on this if you do decide to do the relocation..
The bracket I purchased required the ignition switch to be located in such a way that the vent or hole where the wire harness goes into the housing is pointing straight up. I got drunk one night (imagine that) left my KP outside and it rained a lot. the water followed the wire harness straight down and into the switch with no problem. it completed a circuit which turned on my netural lamp and parasiticly drained my battery. I removed the bracket re-drilled the location of the hole and turned the ignition switch over so that would not happen again...I disassembled the switch it was full of water cleaned it and all is good..
2013 black XCT.
OkieHoss is offline
post #2 of 4 (permalink) Old 03-24-2012, 06:14 PM
gibson's Avatar
I am trying to see where it is in the picture, give me a hint..
gibson is offline
post #3 of 4 (permalink) Old 03-24-2012, 08:15 PM Thread Starter
OkieHoss's Avatar
I rigd the key to look like a nut on a part so as to be hard to find...I guess it workd..
Hamster likes this.
2013 black XCT.
OkieHoss is offline
post #4 of 4 (permalink) Old 03-25-2012, 09:02 AM
Account closed.
upgrayedd's Avatar
Sooooo...do you need a socket and ratchet to start your bike? Lol...j/k. That looks really nice, I like the clean look.
Sent from my DROID RAZR using Motorcycle.com App
'12 Vegas 8ball
upgrayedd is offline
