Dumb question (fuel injection) - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 06-21-2012, 12:41 AM Thread Starter
Default Dumb question (fuel injection)
05' Hammer
on an initial startup (cold)...if i dont let the bike warm up for 3-4 minutes, it will die if i try to pop the throttle. it almost wants to act like is carb'd, which i know isnt the case. Its fuel injected, so you should be able to pop the throttle over right away.
ive recently had a tune up and full fuel injection flush. and 7500 miles service.
any thoughts or is this typical.
faslane is offline
post #2 of 12 (permalink) Old 06-21-2012, 01:20 AM
saintdruss13's Avatar
I'm new to victory too so I'm not some one whos knows a lot about these bikes yet but I've read a lot about them and they say it is very important to let these bike warm up, most say a couple min before riding.
Captain Spalding's Fried chicken and gasoline. * EXIT 13 OFF ROUT 1 at RUGGSVILLE*
2004 TC, 05 Vegas 8Ball, 09 Yamaha FZ6R
Lake Havasu City AZ.
saintdruss13 is offline
post #3 of 12 (permalink) Old 06-21-2012, 01:42 AM
Tims_04V92TC's Avatar
Yes, they are fuel injected but the the V92 likes their warm up time (about 2-3 minutes, summer getting into it easy out of 1st works best for me). Wait until winter gets here and you are next to a Carbed bike and listen to their hassles vs yours.
My start up in warm weather is ignition over with no fast idle, fires up within 2-5 seconds and just let her idle as I am putting my gear on/getting set for the ride. Maybe crack the fast idle just a hair if you want.
Kill the fast idle if I had it on, a couple easy blips on the throttle and off we go. Not so say it may be a little slow on the response until you get past the first mile and I love my leaning so slow and sure wins the race for me. Once at op-temp, runs like a scaddle ape.
Winter start up, open the fast idle just a tad, start and bring it up to about 1300 rpm. 2-5 minute warm up as I am gearing up, keep fast idel on for first mile as I am heavy residential and alot of turns, etc. Come from work, just out to the main road then kill the fast idle. Again, once op-temp (5 min or so) she runs great.
If your getting backfires from blipping cold or not, just the nature of the engine from what I am told. Rarely after a good warm up for me. Hope this helps, safe riding!!!!
Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #4 of 12 (permalink) Old 06-21-2012, 02:59 AM
kevinx's Avatar
While they are injected. They use a very simple system. For the first 90 seconds or until the engine reaches 125. The bike is in full enrichment, and basically showering the engine with fuel. That said if the bike has a clean throttle body, and the TPS. Is adjusted properly; it will run pretty well even stone cold
kevinx is offline
post #5 of 12 (permalink) Old 06-21-2012, 03:08 AM
Seen a good improvement of idle becoming smoother faster at startup after cleaning the TB's but thought the better start and what seemed to be quicker warm up was just due to summer arriving. Glad to know what impact clean TB's make! Hmmm, can't wait for winter to get here now...lol..
IBA Rider
Retired Navy SCPO
Chesapeake Va
post #6 of 12 (permalink) Old 06-21-2012, 04:01 AM
Follow KevinX's advice on the throttle bodies being clean and the throttle position sensor being adjust correctly and it should run fine; even when cold. I currently have two 04 KP's (long story) and both of them run perfect; even when cold. I did pull the tank on one of them and clean the TB's myself since it hadn't been done in a while before I got it and it made an amazing improvement in idle.
I love these v92 Freedom motor's! Power galore and they sound great.
post #7 of 12 (permalink) Old 06-21-2012, 11:23 AM
How often should the throttle body's be cleaned? I just bought my 05 Vegas, it has 10K on it, is this something I should do. (I did run some sea foam through it)
2005 Vegas, Stage 1, Ness Fly Bars, teardrop mirrors, ISO grips and pegs, Bullet headlight, Corbin Hollywood solo seat.
California, MD
UnfixedPyle is offline
post #8 of 12 (permalink) Old 06-21-2012, 12:23 PM
07PEARLJACKPOT's Avatar
i clean mine every other oil change.
KURYAKYN LED BLINKERS
GUNFIGHTER SEAT
KURYAKYN FLAME COMFORTGRIPS
KURYAKYN FLAME PEGS
"JACKPOT" OIL COOLER COVER
CHROME STARTER COVER
MEMPHIS SHADES WINDSHIELD
VICTORY TOOL ROLL
RPW SLASH EXHAUST
S&S INTAKE
KURYAKYN ELLIPSE MIRRORS
07PEARLJACKPOT is offline
post #9 of 12 (permalink) Old 06-21-2012, 12:40 PM
The bike will pretty much tell you when it's needed by the way it idles and runs in general but if it doesn't; every 10k miles is what I go by unless, as I said, something tells me otherwise.
post #10 of 12 (permalink) Old 06-21-2012, 01:34 PM
Goatlocker95's Avatar
I run Seafoam through my bike every couple of months. Is there something else I should be doing to clean the TB?
2014 Indian Chieftain
Goatlocker95 is offline
