Low oil indicator after PV5/Lloydz air filter/pipes installed - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 05-24-2015, 01:36 PM Thread Starter
ChopperJeff's Avatar
Default Low oil indicator after PV5/Lloydz air filter/pipes installed
Just completed the installation of the Power Commander V, Lloydz air filter and Bassani Road Rage pipes. I start the bike and all is well. Then after about 30 seconds the Speedometer indicates Lo Oil.
I check the oil Level and it's fine.
I did disconnect both O2 sensors as suggested by people.
Did I mess something up?
ChopperJeff is offline
post #2 of 14 (permalink) Old 05-24-2015, 01:44 PM
Lostintexas's Avatar
Oil light is a pressure light, not volume. Check around the underside of the bike, follow the wire from the sending unit. Sounds like you nicked a wire or something is loose. Hopefully just a loose plug.
Sorry no pic of the sending unit. I think it is on the left side of the case, but don't take it as gospel.
You may find this of interest. It is a vision, but the 106 is pretty much the same.
https://www.youtube.com/watch?v=4OERayu9O74
I ride with the Force.
Lostintexas is offline
post #3 of 14 (permalink) Old 05-24-2015, 02:33 PM
ndabunka's Avatar
He may have mistakenly disconnected the oil sensor instead of the O2
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
post #4 of 14 (permalink) Old 05-24-2015, 02:36 PM
LILMAGS500's Avatar
Sounds like something is disconnected or loose .....
LILMAGS500 is offline
post #5 of 14 (permalink) Old 05-24-2015, 02:36 PM
when the kickstand is up look straight in and you'll find the sending unit.
auto store sell them. $6 bucks look like this
post #6 of 14 (permalink) Old 05-24-2015, 07:41 PM Thread Starter
Thanks for the input guys! I pulled the seat and made sure the battery connections were good, and looked around at the wires and connectors. Started the bike and ran it for a bit, and the Low Oil never came on. Then did a short ride of about 10 miles and all was good. Maybe I jiggled something that made it happy (got to be a joke in there somewhere). I'll look more closely at the sensor and such as you guys pointed out.
I think I'll get the bike dyno tuned next weekend to make sure all is dialed in. Currently the bike runs fairly well, but back fires on decal, and surges a bit in 1st gear.
post #7 of 14 (permalink) Old 05-26-2015, 12:32 PM Thread Starter
Have ridden the bike now about 60 miles, and no 'Low Oil' indicator coming on (knock on wood). Is it possible that having the battery disconnected confused the ECU?
By the way, I've schedule to have the bike dyno'd this weekend. He said that it can take between 3 and 5 hours to dyno it! Can it really take that long? A friend of mine had his chopper dyno'd by a different place a while back and it was done in about an hour. But then that was a carburetor bike. Just hard to believe it could take that long, but then, what do I know!?
post #8 of 14 (permalink) Old 05-26-2015, 12:45 PM
p.hunt's Avatar
Are you going to Billy Rohm?
If so don't just drop your bike off stay and watch it be done and ask for an advanced map. He is really good at tuning but takes a lot of breaks and customers to talk too. Just a real laied back guy that isn't in a hurry! Lol
2012 Vision - in process of converting to Cross Country rear end and bags
Lloyd's -Filter-Timing wheel-Adjustable Intake-Throttle ring
PCV5
Home built 2 into 1 pipe with dummy pipe on left looks stock
p.hunt is offline
post #9 of 14 (permalink) Old 05-26-2015, 12:46 PM
p.hunt's Avatar
Also get the timing gear put on before you Dyno it!
PCV5
p.hunt is offline
post #10 of 14 (permalink) Old 05-26-2015, 12:51 PM
Were either of the cables loose? Yes is the answer, Victory's are very picky about having a constant power supply.
