1/4 Turn Throttle Ring - Victory Forums - Victory Motorcycle Forum
post #1 of 22 (permalink) Old 05-29-2015, 09:47 AM Thread Starter
epson390's Avatar
Default 1/4 Turn Throttle Ring
Someone please enlighten me on the 1/4" throttle ring. The thought of it being all or nothing sounds terrifying. Is it really that good???
2014 XC - Pearl White - 16" Ape Hangers, LED Headlight, Lloydz Timing Gear @ +4, SharkHonker Exhaust, PCV, 1/4" Turn Throttle Ring, Hard Lowers, Keyless Ignition, Lloyd's Intake, Klockwerk Shield
epson390 is offline
post #2 of 22 (permalink) Old 05-29-2015, 09:52 AM
Pauljp's Avatar
I like mine, I used to have to readjust my grip if I wanted to crank her open to merge or pass or something.
Now I can do it without readjusting my grip.
And it still moves easily at low speeds.
I like it and am keeping it on.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #3 of 22 (permalink) Old 05-29-2015, 10:06 AM
LILMAGS500's Avatar
Best mod you will ever buy for 20.00 . Do it .
LILMAGS500 is offline
post #4 of 22 (permalink) Old 05-29-2015, 10:12 AM
Pauljp's Avatar
And it's not all or nothing... I went from 120 degree twist to 90 degree.
Paul
Pauljp is offline
post #5 of 22 (permalink) Old 05-29-2015, 10:17 AM
Weeds's Avatar
Next on the list... Paul, ill be right up......
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #6 of 22 (permalink) Old 05-29-2015, 10:46 AM
SilvrT's Avatar
I have it also and it makes a BIG difference!
It's name gives a misconception ... it doesn't reduce the grip twist to 1/4 but it will give you the feeling that it's only taking 1/4 of the effort when you crack it from full stop to full open.
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #7 of 22 (permalink) Old 05-29-2015, 10:53 AM
Judge Redd's Avatar
I just got one myself.. Installing soon.
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #8 of 22 (permalink) Old 05-29-2015, 11:01 AM
SilvrT's Avatar
So, if we do the math, that's a reduction of 1/4 ...
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
post #9 of 22 (permalink) Old 05-29-2015, 11:28 AM
Well, I don't know about everyone else's bike, but after installing the 1/4-turn ring on my bike my throttle twist range is now approx. 90.
The benefit is you don't have to twist the wrist as much to get the same throttle response.
broggyr is online now
post #10 of 22 (permalink) Old 05-29-2015, 12:02 PM
p.hunt's Avatar
I still wish it had even less twist after installing mine I want the 1/2 turn throttle! Lol
2012 Vision - in process of converting to Cross Country rear end and bags
Lloyd's -Filter-Timing wheel-Adjustable Intake-Throttle ring
PCV5
Home built 2 into 1 pipe with dummy pipe on left looks stock
p.hunt is offline
