PCV and Lloydz timing wheel info - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 05-30-2015, 01:11 AM Thread Starter
steveg56's Avatar
Default PCV and Lloydz timing wheel info
So I have Lloyd's timing wheel, filter, big honkers and PCV. Timing wheel is set at +4, but also noticed my map I downloaded from PC website has add +2 to 3000-5000 and +3 from 5k up. So i'm assuming I'm running +6 3000-5000 and +7 from 5K up. Does this sound right, or should I adjust the map not to add timing since I have the wheel?
steveg56 is offline
post #2 of 4 (permalink) Old 05-30-2015, 02:26 AM
half_crazy's Avatar
It would be nice to know what part of the world you're in and what model bike we are talking about...
But in any case, you should have the bike tuned on a dyno by someone who knows what they're doing.
Usually the wheel will stay at +4 and they will add a few degrees at 80% throttle and 100% throttle. The canned maps probably do not account for a timing wheel and are a shot in the dark at tuning the bike.
2006 Victory Kingpin
half_crazy is offline
post #3 of 4 (permalink) Old 05-30-2015, 08:26 AM Thread Starter
steveg56's Avatar
Sorry I'm in California and I'm on a X1.
steveg56 is offline
post #4 of 4 (permalink) Old 05-30-2015, 09:53 AM
LILMAGS500's Avatar
Get it dyno tuned , you wont regret it . Those canned maps are garbage .
LILMAGS500 is offline
