ABS Light - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 06-04-2015, 08:30 PM Thread Starter
epson390's Avatar
Default ABS Light
Just recently my ABS light began lighting up intermittently. Will stay on until I try the bike off. Then it might come on but other times it doesn't.
2014 XC - Pearl White - 16" Ape Hangers, LED Headlight, Lloydz Timing Gear @ +4, SharkHonker Exhaust, PCV, 1/4" Turn Throttle Ring, Hard Lowers, Keyless Ignition, Lloyd's Intake, Klockwerk Shield
epson390 is offline
post #2 of 5 (permalink) Old 06-04-2015, 08:48 PM
ABS light will come on at startup(indicating the ABS is inactive) until the bike reaches > 6mph
post #3 of 5 (permalink) Old 06-04-2015, 09:06 PM Thread Starter
epson390's Avatar
Yeah but it turns on 30 minutes into a ride.
epson390 is offline
post #4 of 5 (permalink) Old 06-04-2015, 10:34 PM
Mine did that after riding in the rain. It stopped doing it after the bike dried out and has not done it again...yet. I don't know what happened or how to fix this intermittent problem. Please post if you find the source of the problem and/or a solution. Thanks.
G'day,
Vinish
Vinish is offline
post #5 of 5 (permalink) Old 06-05-2015, 01:12 PM
Term's Avatar
I am pretty sure I have seen some threads about this in the past. Cleaning, adjusting or replacing the sensors was the fix. Do a search, if you haven't already, I think you will find some answers.
2013 Vision Sunset Red - Stage 1 exhaust, VictoryHID Cyclops
2004 Kingpin - Traded
Term is offline
