xbow pipe popping help - Victory Forums - Victory Motorcycle Forum
post #1 of 17 (permalink) Old 06-06-2015, 06:42 AM Thread Starter
Default xbow pipe popping help
Just had x-bow pipes installed on my vic gunner..look great and aren't too loud..perfect....however the popping on decel from like 3rd gear to 2nd or just shifting up from the low gears...(hate it).. will this always happen? is this normal? had everything done at a vic dealer..
thanks
Mark
rideforever is offline
post #2 of 17 (permalink) Old 06-06-2015, 07:08 AM
LILMAGS500's Avatar
Did they do the stage one flash ? Check the flange nuts at the exhaust where the pipes attach to the head , should be 12ft lbs , a leaking gasket will cause popping . Try disconnecting your 02 sensors and see if that makes a difference , if not reconnect them , if its better , leave them unplugged .
LILMAGS500 is offline
post #3 of 17 (permalink) Old 06-06-2015, 07:24 AM Thread Starter
thanks ill check for leaks...it was installed at the dealer and was told kit came with its own hi flow filter and flash code from vic....
post #4 of 17 (permalink) Old 06-06-2015, 08:00 AM
LILMAGS500's Avatar
Keep in mind when changing out the stock exhaust , some popping will be present , there is no avoiding it .
post #5 of 17 (permalink) Old 06-06-2015, 08:58 AM
jbb01's Avatar
Mags is correct...you can't really avoid it. There are some things you can do (idle air valve, PCV, tuning, timing wheel, etc...) to decrease it but inevitably it will pop some. Try not to ride it like a sport bike and you will see less popping
2011 Hammer 8-ball
VM-1 cams
TT intake
RPW Thor
Lloyds ATS
2001 Honda RC-51
jbb01 is offline
post #6 of 17 (permalink) Old 06-06-2015, 12:36 PM
what Mags said but it might take 3 or 4 times to get them tight. Check after each ride
post #7 of 17 (permalink) Old 06-06-2015, 12:43 PM
Minimum right wrist movement between shifts equals minimum popping.
post #8 of 17 (permalink) Old 06-06-2015, 03:15 PM
DVega's Avatar
yup...chopping your throttle on/off will definitely produce popping. I can make mine pop at will haha
Fuck victory
DVega is offline
post #9 of 17 (permalink) Old 06-06-2015, 03:16 PM
MC Hammer's Avatar
Is it popping or crackling?
I love the smell of Freedom in the morning... smells... smells like... Victory! ©
MC Hammer is offline
post #10 of 17 (permalink) Old 06-06-2015, 03:46 PM
Better you should ask, Is it Snapping, Crackling or Popping?
