NY Plate Frame - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 06-07-2015, 10:14 PM Thread Starter
gvales's Avatar
Default NY Plate Frame
I posted in wrong forum initially, hopefully admin will delete other one...
Along with a few other states, NY motorcycle plates have a odd license plate hole location. I believe most plate holes top to bottom OC are 2 3/4", where NY has a 3" OC distance.
Has anyone (in NY) found decent plate frames that allow using that NY hole alignment for all 4 screws?
2009 Nuclear Sunset Premium Hammer
Llyodz ATS +4,Vic Mini Shield,Hacker Rippers w/ams,Victory Hi Flow air intake kit w/ vents,Chrome Battery Cover,Hydraulic Clutch,Kuryakyn Clutch Cover,Kuryakyn Cam Bolt Covers
2012 CrossRoads LE #177
Llyodz ATS +4,Victory Pass Backrest,Stage 1 RPW Exhaust,New Tank Badge,Victory Tachometer,VictoryHid Hi/Lo 5K,5k Driving Bulbs,Victory Cam Bolt Covers,Chrome Clutch Cover,Chrome Plate Bracket,RICZ Plate Bracket,Heel Shifter,O2 plugs
gvales is offline
post #2 of 7 (permalink) Old 06-07-2015, 10:22 PM
Call some of the local bike shops. NY is a big place so I imagine someone is making some money from them. Barring that, drill your plates to whatever cover frame you like.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #3 of 7 (permalink) Old 06-07-2015, 11:04 PM
i agree. If the plate frame I am using doesn't fit I have drilled the holes where needed. When they change the color or design of the plates again I just do the same again with the new one. I hope someone has a site to find what you need.
2013 Cross Country Anti-Freeze Green
Lloydz Timing wheel set at 4 degrees
Lloydz High Flow air filter
Llodz Peformance Cams HOH-VM1-DR
Lloydz Dyno Tuned
Atom Bomb exhaust
113/119
gpd445 is offline
post #4 of 7 (permalink) Old 06-08-2015, 05:28 AM
DirtyDan's Avatar
I wouldn't sweat it. Just drill new jokes in the plate.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #5 of 7 (permalink) Old 06-08-2015, 06:38 AM
AfterDarker's Avatar
Will ruin the look of his number plate by drilling holes in it, lol
2013 Victory Judge
Bling: RPW Thor 2into1, Llyodz ATS, air box, ECU.
AfterDarker is offline
post #6 of 7 (permalink) Old 06-08-2015, 07:50 AM
MonsterMash's Avatar
no luck in all my years riding... redrill is pretty much the only option. luckily the frame usually hides the extra holes...
that is if you can keep your plate together for more than half a riding season.. had my hammer for over 4 years and i usually end up going through 2 plates in a season because they all stress crack in half.. NY is good about having cheap ass plates. never had this problem when it was the stamped metal plates.. ever since we went to just the painted aluminum crap, regardless of the bike, its always gotten stress cracks and breaks around the top mounting holes.
stupid NY...
you got your jesus on the dashboard, the devil's under my hood. you're takin' down to legal, i'm pulling it up to no good.
god is your co-pilot, i let satan ride shotgun, you pay a toll to get to heaven, but on the road to hell there's none..... \m/ \m/
2010 Cross Roads
Navy - Its not just a job, its an adventure :)
MonsterMash is offline
post #7 of 7 (permalink) Old 06-08-2015, 08:37 AM
Mr_Buzzcut's Avatar
stupid NY...
I went through 2 plates in a week when I first got my Hammer. First one fell off, and the second one stress cracked and was hanging off! The third one I smoothed and deburred the mounting holes. It's holding on so far.
Re: the OP, I also had to trim my plate to fit the plate frame.
2008 Hammer S
300mm Fat tire
USMC 87-92
Mr_Buzzcut is offline
