Polishing brake reservoir??? - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 06-09-2015, 12:15 PM Thread Starter
Default Polishing brake reservoir???
Wanting to polish my brake and hyd clutch reservoirs on my handlebars. Witchdoctors used to do the service but has stopped. Has anyone here done it and have any tips for getting the powder coat off?? Any tips or advice appreciated.
2012 XC..Tri ovals..forged bars....vic baggers bag fillers..XC mitered chubby bars..chrome switch housings..LLoyds timing wheel, lowered 2", WD floorboards...the list keeps growing..
olemissalum is offline
post #2 of 3 (permalink) Old 06-09-2015, 01:58 PM
Bead blast the powder coat off.
Going to need to sand it in stages down a glass smooth surface. More than likely a dremel will be needed for the tight spots.
Sand in a straight line and when you get to the finer grits, soak the sandpaper in water so it wont clog with metal.
A polish wheel with rouge and back to the dremel for the tight spots.
The smoother you sand and the longer you run it on the buffer the higher the finish quality.
Just in case, I want to point out the obvious, it will not be a 'chrome' luster. If that is what you are looking for you will need to send it off to have it chromed.
There are a ton of videos on youtube showing how to polish metal. It doesnt take any real skill, just some time and patience.
Sportsmanphil is offline
post #3 of 3 (permalink) Old 06-09-2015, 02:45 PM
soofle616's Avatar
Originally Posted by Sportsmanphil View Post
Everything he said. Polishing stuff is a major PITA, not because it's hard but because you have to be very patient and keep at it.
Whatever you do, MAKE SURE that you sand away all the scratches from the previous grade of sandpaper before moving on to the next (ie, use 800 to remove all the scratches from the 600 before moving on to 1000)
While you will eventually get there skipping grades of paper or not getting all the previous scratches smoothed, it will take you a whole lot longer if you try to rush it.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
