Bike won't start in gear - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 06-16-2015, 11:47 AM Thread Starter
Lightbulb Bike won't start in gear
Howdy All,
Well, I did as much searching as I could, and I won't lie I couldn't find much about this issue, so I'm creating a post in general discussion for any information that you all can provide.
I have a 2013 Victory Highball with roughly 5,500 miles on it. In the last week my highball will no longer start if my bike is in gear, with the clutch pulled in. I know some may advise against this, and to each their own, but reading my manual the bike should be able to start while in gear and clutch pulled in. This is the way I've been starting my bike for the last two years, so I know it should do this. My bike starts perfectly fine when in Neutral, however it won't start at all in gear. Am I missing something? Can any light be shed on this situation?
This is the exert from my manual about starting in gear:
"The starter interlock system allows the engine to be started only when the transmission is in
neutral, or when the transmission is in gear with the clutch disengaged (clutch lever pulled
in)."
Again, any information would be greatly appreciated.
-HT
2013 Victory High Ball
"Lola"
Cobra Fi2000 PowerPro
Bassani Pro Street Turnouts
K&N Filter
Amsoil Synthetic
HunnieToast is offline
post #2 of 8 (permalink) Old 06-16-2015, 11:50 AM
Check the clutch switch. It's a small switch that opens and closes with the clutch lever.
post #3 of 8 (permalink) Old 06-16-2015, 12:24 PM
Kingsrule5's Avatar
I second the clutch switch. It should still be under warranty at your mileage.
2014 XC Boss Blue/Gloss Black
Tri-Ovals
Lloydz ATS +4
Lloydz Air Filter
1/4 turn throttle
PBR300x2+Alpine SPS-510
Goody Lowers
Klock Works windscreen
2006 Suzuki GSXR 600
Kingsrule5 is offline
post #4 of 8 (permalink) Old 06-16-2015, 12:37 PM
DillPickle311's Avatar
I always make sure I'm in neutral anyway because I have to back my bike into the garage.
I'm glad because if I had gotten in the habit of cranking it while in gear, it may not be in the right one and there could be an emergency requiring me to move my arse quickly.
When it's time to go, I need to be sure about my direction, that my mode of movement is reliable, and that I look good doing it.
DillPickle311 is offline
post #5 of 8 (permalink) Old 06-16-2015, 01:22 PM
soofle616's Avatar
Almost definitely the clutch switch. Make sure it's connected and if it is, test it for proper function. If it doesn't operate properly, replace it. If it does, there's a high probability that you have a short somewhere that's causing the bike to not see the switch when the lever is pulled.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #6 of 8 (permalink) Old 06-16-2015, 01:38 PM
busajack's Avatar
I need to be sure about my direction.
No worries Dill i think there is a lock out switch for the Reverse gear also.
I have to grow old but I don't have to grow UP.thumb up. 2010 Jackpot.
busajack is offline
post #7 of 8 (permalink) Old 06-16-2015, 04:30 PM
My clutch safety switch on a 2012 Vic XCT failed. It was trivially simple to replace but cost about $60. You can easily test it with an ohm meter. See if it changes from 0 to infinite resistance when you pull the clutch lever. It might be infinite to zero when you pull the lever, I can't remember, but the key is that it should change radically in the resistance across the wires when the clutch lever is pulled.
G'day,
Vinish
Vinish is offline
post #8 of 8 (permalink) Old 06-17-2015, 10:40 AM
My old Vegas did this a few times just needed adjustment and tightening of the clutch lever switch.
2008 Suzuki B King,2010 Vegas 8 Ball,2006 BMW Z4.
goon is offline
