Right side bag latch repair - Victory Forums - Victory Motorcycle Forum
post #1 of 17 (permalink) Old 06-17-2015, 11:42 PM Thread Starter
Default Right side bag latch repair
I bought hard bags for my CR when they were half price, and did the washer thing and elongated the holes in the latch so I wouldn't have the problem many have with wear. Well, after a couple thousand miles I saw the beginning of a notch anyway. So here's my fix, I think it should be a final repair for anyone with this problem. It's a U nut from Ace, about 50 cents. Make sure it has the full back...many have a cutout which wouldn't do. The screw is to keep it from shifting, and cut off to allow the mechanism to latch.
mtsiview is offline
post #2 of 17 (permalink) Old 06-18-2015, 01:12 AM
Omg that's perfect.
Brilliant too.
Very nice. I love simple solutions !
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #3 of 17 (permalink) Old 06-18-2015, 06:15 AM
dentdave's Avatar
That's a nice fix, take a file and round off the corners of the metal tab that way it won't scratch or cut you. Sorry , that's my Dad always telling me that over the years so when ever I see sharp corners I always think " round them off"
David
www.dentdave.com
2012 Cross Country Tour
IBA # 33520 - 1040 in 24, 04 / 2008
1036 in 24, 10 / 2014
Michelin Primacy Alpin PA3 ZP 195/55/16
dentdave is offline
post #4 of 17 (permalink) Old 06-18-2015, 08:28 AM
Not a bad way of thinking at all.
post #5 of 17 (permalink) Old 06-18-2015, 08:29 AM
Highvoltagehands's Avatar
You're not going to out cheap me and my paperclip fix. Snap on paperclip, then remove leverage tabs. Done. Washer worked fine for me, guess I just had something cheap to prove.
2013 Arlen Ness XC
Granite Bay, Ca
Highvoltagehands is offline
post #6 of 17 (permalink) Old 06-18-2015, 08:30 AM
I dig it!
post #7 of 17 (permalink) Old 06-18-2015, 10:56 AM Thread Starter
Highvoltage,
Looks like this narrowback has been outdone! Cheaper and quicker, nicely done.
mtsiview is offline
post #8 of 17 (permalink) Old 06-18-2015, 11:41 AM
Highvoltage,
Right on Narrowback. I was a wireman too, before switching to Outside Line. Some of the guys still refer to me as "Switchback" lol.
Wiremen wire buildings…… Linemen wire Cities…….
Hud
2013 Arlen Ness XC
Granite Bay, Ca
post #9 of 17 (permalink) Old 06-18-2015, 08:41 PM
AllenT's Avatar
I had to try the binder clip trick posted by Highvoltagehand and I am here to tell you it is a PERFECT repair for the worn latch piece. I dug through my junk drawer until I found the "micro" size..."mini" was a bit too wide to fit. Removed the wings from the clip, slipped into place...INSTANT fix. It's like it was MADE for this precise application.
Use it along with the washer under the front mounting hole and your latch should last and last.
MTSIVIEW's idea is a good one, too.
Ingenuity gentlemen... I am jealous!
AllenT is offline
post #10 of 17 (permalink) Old 06-18-2015, 10:43 PM
Victory should be ashamed that the spring steel in a binder clip is probably stronger and will last longer than their response to this problem. Glad it wasn't anything major.
2013 Arlen Ness XC
Granite Bay, Ca
