Tranny Noise - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 06-19-2015, 11:39 PM Thread Starter
Default Tranny Noise
Guy on FB
"Tech Question: We got a 2014 Ness XC that came in with a loud tranny noise when you leaned the bike over to the right while idling in neutral? Loud clacking!!
We tore the whole thing down, replaced some tranny parts and now he is back in with the same problem about 1000 miles later??
Need good advice on what it might be? Thanks"
every one said clutch and bad Tranny.
Keninx said
"Kevinx Cross The problem is a worn thrust washer on the shaft. It is either on backwards, the linkage is set up weird, the rider needs smaller boots, or needs to learn to quit loading the shifter while riding"
post #2 of 13 (permalink) Old 06-20-2015, 01:39 AM
I see your point is to point out that pre-loading the shifter isn't such a great idea even if it makes the shifting smoother.
As to your question about tranny's; shouldn't you ask someone like Caitlin Jenner who knows first had about all the strange noises a tranny makes?
post #3 of 13 (permalink) Old 06-20-2015, 03:38 AM
Motorbikerx's Avatar
riding with the shifter loaded and pre-loading just prior to a shift are two different things.
was the tranny pre or post op?
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 13 (permalink) Old 06-20-2015, 06:21 AM
OkieHoss's Avatar
Yep, its ok to preload some but this is like resting your hand (foot on shifter)on a stick shift. It causes premature wear.
2013 black XCT.
OkieHoss is offline
post #5 of 13 (permalink) Old 06-20-2015, 09:49 AM
2010 Victory Vegas Low
Stage 1
Lloydz ATS 4*
Custom paint and pinstripe
Blakely, Georgia
RockimGa is offline
post #6 of 13 (permalink) Old 06-20-2015, 01:01 PM
That makes better sense. I never got into the habit of pre-loading the shifter just prior to shifting. The clunk is just something I got used to I guess.
post #7 of 13 (permalink) Old 06-20-2015, 03:42 PM
HowardGNelson's Avatar
damnit Bbob, you beat me to the Caitlin Jenner comment.
2012 XCT Sunset Red - D&D's, Lloydz filter, ATS +4, Clearwater Krista's, Fusion LED kit, Rusty Jones single din, Sony head unit, PCV, BAB Tank Lift, BAB 1/4 Turn, Kenwood 400x4 amp, Soundstream 1000x4 amp, Focal 6.5s, DS18 tweeters, Polk Audio DSi5.25s, Rick Fairless mini apes
RIP my 2010 Victory XC-Skull bike (Totaled 10/21/16)
07 Jackpot Premium - white w/ flames(SOLD)
**Stop saying "how dumb can you be", people seem to be taking it as a challenge**
HowardGNelson is offline
post #8 of 13 (permalink) Old 06-20-2015, 10:20 PM
Every once in a while I get the early worm.
Umm... don't read anything into that. I'm a boob and butt man. You can keep the worm.
post #9 of 13 (permalink) Old 06-21-2015, 02:07 PM
thats really funny, because she isn't
by the way i hope you dont mind, i have sent about 6 people from FB your way on the heat shields. so if you start getting PMs from newbies...
post #10 of 13 (permalink) Old 06-21-2015, 02:42 PM
