riding hot, hot, hot! - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 07-13-2015, 06:31 PM Thread Starter
Default riding hot, hot, hot!
First of all, please let me state that my search feature hasn't worked since getting my Samsung tablet so I can't look up anything. With that said, I put a set of Hush mufflers on from Hotvic and a new timing gear with a new chip for the fuel as well as an air filter. Now the question:: it seems that the heat at the back of the engine is incredible. Now it could be that it's because it's 90 plus degrees, but still the rubber inserts on my passenger pugs are coming unglued. Is there a way to cool down this engine? I know I could takeoff the cat converter, but I don't want to loose the torque.
Jim
2013 Victory Cross Country
Black with Flames
Motor62 is offline
post #2 of 14 (permalink) Old 07-13-2015, 07:06 PM
MC Hammer's Avatar
Do aftermarket pipes such as RPW, Hacker for steel frames have cats in them?
I love the smell of Freedom in the morning... smells... smells like... Victory!
MC Hammer is offline
post #3 of 14 (permalink) Old 07-14-2015, 04:37 AM
Lostintexas's Avatar
The "chip" you speak of I and guessing is the factory ECM flash for stage 1. You probably need a tuner with the mods mentioned. Try unplugging the O2 sensors to see if that helps any.
I ride with the Force.
Lostintexas is offline
post #4 of 14 (permalink) Old 07-14-2015, 05:27 AM Thread Starter
Yes the 02 sensors are unplugged.
Jim
Black with Flames
Motor62 is offline
post #5 of 14 (permalink) Old 07-14-2015, 05:34 AM
philmonger's Avatar
Get a fuel contoller. You are almost certainly running way too lean...
2011 XR Midnight Cherry, Hard Bags, Vic htd grips & seat, Vic medium Windshield, unlocked speedo, Lloydz Air filter, VFC III, Lloydz ATS +4, Vance & Hines slip ons
1993 Vulcan 1500 (sold)
1981 Yamaha Seca 750 (ridden into oblivion)
1977 Honda 550 (sold)
philmonger is offline
post #6 of 14 (permalink) Old 07-14-2015, 07:24 AM
soofle616's Avatar
This. And do it quickly. If you're running that lean you risk damaging the engine from the excess heat.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #7 of 14 (permalink) Old 07-14-2015, 08:26 AM
DVega's Avatar
your shit is running hot because it is super lean. get it tuned, get it tuned now and don't hammer the shit out of it until you do.
Fuck victory
DVega is offline
post #8 of 14 (permalink) Old 07-14-2015, 12:06 PM
now this is heat
File Type: jpg MotoGP Rider Escape His Flaming Motorcycle (2).jpg (32.4 KB, 7 views)
post #9 of 14 (permalink) Old 07-14-2015, 12:11 PM
Yep. At the very least get a Dobeck style tuner and if you plan on cams at a later date; get a PC-V. I like the Auto Tune module you can get as well so it tunes as you go. You can get both for around $600.
These are air cooled engines so they will be hot on hot days. I imagine the humidity plays into it too. Tuned correctly it can be reduced down to a tolerable level.
Are you feeling it on your inner and back of your thighs or is the seat getting hot to your butt? If the seat is getting hot you can put some heat insulation under the seat. Auto parts stores sells the stuff with adhesive on one side so you can stick it to the underside of your seat.
post #10 of 14 (permalink) Old 07-14-2015, 12:54 PM
Bbob would your heat shield work in this case?
2013 xct bronze
VM1 DR-T "Touring" cams
Lloydz air filter
Timing wheel at 5 deg
Quarter turn throttle
D&D's wrapped
Tuned from The Vic Shop 8/14/15
Dyno 123hp 117tq
Led headlight
Digital guard dawg
HMD gorilla bagger bars
Centermatic wheel balancers
Hydraulic clutch
2015 xct black wife's
Leman crossfire trike kit
Quarter turn
Big gonzo mufflers
2 inch pull back bars
Vm1 cams
Air filter
Timing wheel +2
Pcv
Properly tuned by the vic shop on the street
refuse2 is offline
