Spark Plug Expert Help - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 07-14-2015, 03:40 PM Thread Starter
DillPickle311's Avatar
Default Spark Plug Expert Help
I have a set that I did not install on last bike... 2003 Kaw Meanie
I see that NGK #5958 CPR6EB-9 will fit
The set I have is NGK #3901 CPR7EA-9 and supposedly is not a fit for my 2004 Vegas. The only upgrade it has it Lloyd Big Sucker filter kit.
What say you?
DillPickle311 is offline
post #2 of 14 (permalink) Old 07-14-2015, 03:42 PM Thread Starter
A year ago I installed Champion 654 high perf
Still running very well.
post #3 of 14 (permalink) Old 07-14-2015, 04:36 PM
Pop
Don't use Pulstars.
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
post #4 of 14 (permalink) Old 07-14-2015, 05:49 PM
Even if they physically fit the bike. I would not use them. A set of plugs even at my no discount ever dealer. New NGK plugs were only about 13.00 bucks. To me That's not worth messing around with the wrong plugs.
99 Kawasaki Vulcan 800 (sold)
2012 Vegas (traded)
2013 Cross Country Tour
Victory Tri-Ovals, Reverse Kit, Lloydz air filter, Lloydz quarter turn throttle ring, PCV, Lloydz Touring cams, HMD Bars, DGD keyless ignition, Rockford Fosgate Amp, klockworks windshield. 119hp 123lbs torque.
jchris56 is offline
post #5 of 14 (permalink) Old 07-14-2015, 05:51 PM
there is a thousand plugs that will fit BUT
some could be to cold and others could be to hot.
Look on the net if you don't understand hot and cold plugs
stay with whats stock you can't go wrong.
post #6 of 14 (permalink) Old 07-14-2015, 06:14 PM
Lostintexas's Avatar
Not sure what stock plugs are on your model. All the big 4 tuners, and motor heads here, say pretty much the same thing. BONE stock plugs. I just bought from a Vic dealer because it was handy a set. $10.95 out the door. Cheap enough, and seem to be something that even the most HP sqeezin Vic junkie can agree on.
A rare case that that many actually agree.
I ride with the Force.
Lostintexas is offline
post #7 of 14 (permalink) Old 07-14-2015, 06:33 PM
Motorbikerx's Avatar
Ditto...use the recommended plugs.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 14 (permalink) Old 07-14-2015, 08:01 PM Thread Starter
Yep! That is the reason I asked here. I've known some to try hot or cooler and would never risk unless someone here has same motor/upgrade and have tried this plug in question. I'd rather spend $20 than break my toy.
post #9 of 14 (permalink) Old 07-14-2015, 08:26 PM
There are some very good reasons why spark plugs of different manufacturer, resistance, length and especially heat range are used. If you don't know what those reasons are, don't use them.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #10 of 14 (permalink) Old 07-15-2015, 04:46 AM
I bought the right plugs for my Kingpin from my local NAPA for less than three bucks apiece. Don't risk damaging your engine with the wrong plugs
Gdfishwell Galveston,Tx 2008 Kingpin Tour Lloyd's timing wheel set at +3degrees, kuryakyn isogrips, kuryakyn throttle lock with matching left side bar end weight
gdfishwell is offline
