Load equalizers, and turn signals - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 07-21-2015, 05:35 PM Thread Starter
Default Load equalizers, and turn signals
Hello to all, I am sure what I seek is on here in bits and pieces and ive found some but not all. So what I am in need of is some clarification. I purchased a 04 vegas recently, love it , but previous owner but strip leds in back on fender and led regular style turn signals on front. they blink fast no big susprise. so now I need to install load equalizers, ive ordered them and researched to find that the blue and blue/red wires are my turn signals. now can I wire the load equalizer for the front into the headlight bucket? and can I wire up the rear one under the seat at the connector for the rear turn signals brake light?
any help is greatly appreciated, I hope im on the right track.
also previous owner put the license plate on a side mount of axle bolt with no illumination, can I wire up a license plate light to the purple wire in the harness under the seat, the same one as the turn signals harness, and use the same blk negative wire as the turn signals.
justin317537 is offline
post #2 of 3 (permalink) Old 07-22-2015, 08:16 AM
kevinx's Avatar
All you need is one set of equalizers in the bucket, and you will be covered.
Yes you can tap the purple wire for a tag light
kevinx is offline
post #3 of 3 (permalink) Old 07-22-2015, 11:23 AM
justin317537
make sure you have a voltmeter or a way to test the wires. On the right side the power wire is not the same color as the left side.
Go to auto store and buy a tester
