Strange highball clutch issue - Victory Forums - Victory Motorcycle Forum
post #1 of 17 (permalink) Old 07-25-2015, 05:46 PM Thread Starter
Dustin0479's Avatar
Default Strange highball clutch issue
I have noticed recently on he highball when it is in gear but the clutch pulled in it is very hard to push, in neutral it is fine. Almost like the clutch is not disengaging. Seems to run fine although she shifts a bit tougher than the XC.
Early signs of clutch failure?
Dustin0479 is offline
post #2 of 17 (permalink) Old 07-25-2015, 06:10 PM
Pauljp's Avatar
Yup I noticed this as well on my XCT.
Engine on or off and in neutral, it is always easy to push.
With the engine running, in gear and clutch pulled in, it is easy to push.
With the engine off and clutch pulled in it is hard to push.
I guess it is just the way it is.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #3 of 17 (permalink) Old 07-25-2015, 06:11 PM Thread Starter
Dustin0479's Avatar
Exactly what I experience.
The XC does not seem to have the same problem oddly.
post #4 of 17 (permalink) Old 07-25-2015, 10:13 PM
slyman's Avatar
Trying not to make this an oil thread, buuuuuut, your oil is making your clutch plates stick together just a little bit. Wait till winter, it'll really stick!
06 vegas 8ball
lloydz timing kit @5 degrees
lloydz torque tubes
trask hot rod, 2 into 1pipes
Pclll
lloydz drop in cams
1/4 turn throttle
2 inch lowering links
highball handlebars
113 hp 123 ft. Lbs. Torque
progressive shock
slyman is offline
post #5 of 17 (permalink) Old 07-25-2015, 10:41 PM
Is it different cold vs hot?
Sportsmanphil is offline
post #6 of 17 (permalink) Old 07-25-2015, 10:43 PM Thread Starter
Dustin0479's Avatar
A little bit
post #7 of 17 (permalink) Old 07-25-2015, 11:53 PM
slyman's Avatar
Yes, cold oil is thicker, hence 'stickier' than warm oil
06 vegas 8ball
lloydz torque tubes
Pclll
lloydz drop in cams
1/4 turn throttle
highball handlebars
progressive shock
slyman is offline
post #8 of 17 (permalink) Old 07-25-2015, 11:54 PM
Motorbikerx's Avatar
Entirely normal, why would someone desire to push thier bike in gear with the motor running and the clutch pulled in?
They're really designed to be ridden not pushed.
Its the drag of the clutch plates.
When kickstarting my old XS650 Yamaha even in neutral I used to pull the clutch in and give the kicker one go and I could actually feel the plates fully release by the kicker going through its stroke a lot easier.
Then it was fuel on, ignition on and in one kick she would fire up( ok sometimes 2 kicks depending on how the planets were aligned)
Clutch drag.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #9 of 17 (permalink) Old 07-26-2015, 12:04 AM
That's normal for it to be like that
vcc14 is offline
post #10 of 17 (permalink) Old 07-26-2015, 05:17 AM
If it more of an issue cold, Id vote an oil issue, but not one that has to be addressed. Every bike I have ever owned was like this cold. The heavier the bike, heavier he clutch the more sticky it was cold.
