Unsticking Bolts Or Drain Plug - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 07-25-2015, 06:52 PM Thread Starter
Default Unsticking Bolts Or Drain Plug
auto stores carry this
http://www.henkelna.com/industrial/p...=8797940809729
post #2 of 8 (permalink) Old 07-25-2015, 06:55 PM
Dustin0479's Avatar
Air cans used for electronic cleaning works too, just takes a good bit.
Dustin0479 is offline
post #3 of 8 (permalink) Old 07-25-2015, 07:18 PM
Ghost_Rider's Avatar
That looks similar to "Rost Off" make by Wurth. Pretty good stuff, will have to try the loctite version
2003 V92C
Wrapped RPW Slash pipes
K&N air filter
Stebel Nautilus
Viking saddlebags
16" apes
Ghost_Rider is offline
post #4 of 8 (permalink) Old 07-26-2015, 09:52 PM
A couple years ago I read a comparison test of a few penetrating oils/fluids and the best by far was a home made brew of 50% transmission fluid and 50% acetone.
RICZ is online now
post #5 of 8 (permalink) Old 07-27-2015, 08:19 AM
wspollack's Avatar
Ric, that Loctite Freeze & Release -- see link in VJ's post -- also asserts that it will also drop the temp way down, which sounds like it may be very useful in that sort of situation. The tranny/acetone mix won't do that, right?
I've been using PB Blaster for stuck bolts over the years, but that Loctite seems like an interesting product, which I learned about only yesterday (on the other forum).
Cheers,
Bill P.
wspollack is offline
post #6 of 8 (permalink) Old 07-27-2015, 08:27 AM
Motorbikerx's Avatar
Eucalyptus oil
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #7 of 8 (permalink) Old 07-27-2015, 08:31 AM
soofle616's Avatar
Tried that loctite stuff years ago, didn't do a damn thing other than waste a couple bucks. The concept has some legitimacy to it but in practice it just didn't work for me. I stick with pb blaster or seadoo lube.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #8 of 8 (permalink) Old 07-27-2015, 12:28 PM
Originally Posted by wspollack View Post
I've been using PB Blaster for stuck bolts over the years.
Me too, until I learned about the superior tranny fluid / acetone mix.
RICZ is online now
