2016 Victory Electric Bike? - Victory Forums - Victory Motorcycle Forum
post #1 of 22 (permalink) Old 07-27-2015, 09:14 PM Thread Starter
russellh575's Avatar
Default 2016 Victory Electric Bike?
2016 Empulse TT from Victory Motorcycles
This is a street legal electric race motorcycle. Built on the same platform that set an American lap-speed record at the Isle of Man, it accelerates up to 100MPH+ and the battery fully charges in 3.5 hours. Where it matters most, the Empulse TT is fast. It is 10,400 watt hours of proof that Victory doesn?t just prove performance, we advance technology. The sport-tuned inverted front forks and adjustable suspension are engineered to provide track-level performance. It has the fastest battery charging speed, greatest lean-angle, and advanced regenerative braking system. Wherever the Empulse goes, it electrifies all audiences.
2015 ISLE OF MAN TT
Where there is no room for error, we proved performance. The Isle of Man TT is the fastest, twistiest, and gutsiest race on two wheels, the perfect location to introduce the world to our electric motorcycle. For 37 miles, we pushed a top speed of 144.34 MPH. We averaged 111.62 MPH. We set the record for an American electric bike, and it was our first attempt. We didn?t just prove that we belong; we stepped up on the podium, and proudly waved the flag of modern American muscle.
THE FASTEST CHARGING BATTERY ON THE MARKET
The Empulse?s battery fully recharges in 3.5 hours, and up to 80% in two hours. With a battery capacity of 10,400 watt hours, the Empulse TT can achieve up to 140 miles of range per charge. Advanced regenerative braking returns power to the battery every time you let off the throttle, and all this battery technology comes with a 5-year warranty. No matter how you measure it, this is the best performing electric motorcycle battery on the road.
100+ MPH TOP SPEED.SHORTEST STOPPING DISTANCE. GREATEST LEAN ANGLE. RIDER-SELECTABLE SPORT MODE.
You can take the motorcycle off the racetrack, but you can?t take the race out of this motorcycle. The innovative drive train is designed specifically to maximize power delivery and speed, while the dual Radial Mount Brembo brakes bring all that power to a quick stop. The high performance adjustable rear suspension and sport tuned inverted front forks let the rider attack every corner, so no matter where the road turns, you can drag a knee. ??
Specifications
2016 Victory Empulse TT
MSRP: Starting at $19,999 USD
Engine
Type Internal Permanent Magnet AC Induction
Peak Motor Power 54 hp
PEAK TORQUE 61 ft-lbs
TRANSMISSION 6-speed gearbox with multi-plate, hydraulic activated wet clutch
BATTERY Brammo Power Lithium Ion
CHARGE TIME 2.0 hrs (Level I / 20 to 80% SOC) 3.5 hrs (Level II / 0 to 100% SOC) 8.0 hrs (Level I / 0 to 100% SOC)
EMISSIONS None
MAX SPEED 100+ mph / 161 km/h
DRY WEIGHT 460 lbs / 213 kg
russellh575 is offline
post #2 of 22 (permalink) Old 07-27-2015, 09:16 PM Thread Starter
Looks like the page has already been removed. Seems pretty legit
post #3 of 22 (permalink) Old 07-27-2015, 10:52 PM
Krisd's Avatar
Good catch Russell, and I hope it is for real. Guess we'll find out tomorrow (the 28th that is)
2012 Hammer S
Freedom Performance pipes now wrapped, PCV, Loyds air filter, ATS, Loyds Cams and 1/4 Turn Throttle adj, Progressive rear shock
300mm rear and 23" front
Krisd is offline
post #4 of 22 (permalink) Old 07-28-2015, 02:50 AM
BBob is online now
post #5 of 22 (permalink) Old 07-28-2015, 07:31 AM
But what is the range on the Vic electric Empulse TT?
G'day,
Vinish
Vinish is offline
post #6 of 22 (permalink) Old 07-28-2015, 08:14 AM
rhino 2's Avatar
I had an Electric bike,
The problem with it was every time i made a ''U'' turn the extension cord would get tangled in the rear sprocket...
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #7 of 22 (permalink) Old 07-28-2015, 08:26 AM
Travis P's Avatar
G'day,
Vinish
130-140 miles before needing a 3.5hr charge.
Travis P is offline
post #8 of 22 (permalink) Old 07-28-2015, 10:11 AM
That would work as a commuter bike for me easily and, I suspect, most people. However, if all you want is a bike for commuting to work, get a used Honda Rebel 250 cc for $2000 and get 70mpg or get a little Ninja (Ninjette?) used. The cost difference between these and the $20K for a new Vic electric bike would buy a lifetime of gas for either of these small bikes.
G'day,
Vinish
Vinish is offline
post #9 of 22 (permalink) Old 07-28-2015, 10:17 AM
Travis P's Avatar
G'day,
Vinish
I agree... The amount of energy used to charge that battery once probably equals 6 months of pollution on a little shadow or ninjette. Green is cool though so Vic will probably sell the shit out of these things to the hipsters.
Travis P is offline
post #10 of 22 (permalink) Old 07-28-2015, 10:22 AM
BP6666VR's Avatar
Dry weight ?? Meaning without the driver ?
Cross Country Tour 2014 [B]
BP6666VR is offline
