painting abs textured plastic. - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 08-02-2015, 09:17 PM Thread Starter
eotsis1's Avatar
Default painting abs textured plastic.
I got a trailer to pull behind my '09 ice blue Vision.
Wondering what preparation is needed to paint the matching victory blue to the top.
What primer is recommended for this surface and under vic paint?
1 Corinthians 15:57 But thanks be to God! He gives us the victory through our Lord Jesus Christ.
2009 Vision... Lloyd cams, pipes, timing wheel +4, power commander V, gps, xm, centramatics, DARKSIDE
eotsis1 is offline
post #2 of 6 (permalink) Old 08-02-2015, 09:29 PM
CHAINSAW's Avatar
Id recommend sanding with some 320 or 400 until its fairly smooth, then follow with Epoxy paint for adhesion. Then follow with whatever primer you choose for filling and blocking.
CHAINSAW is offline
post #3 of 6 (permalink) Old 08-02-2015, 09:37 PM Thread Starter
eotsis1's Avatar
wouldn't epoxy paint/primer be hard? This plastic is very flexible.
Thinking it (the epoxy) would crack easily ???
eotsis1 is offline
post #4 of 6 (permalink) Old 08-03-2015, 06:10 AM
Tarzan's Avatar
You prep with adhesion promoter after final sanding. I painted a fairing and saddle bags and they came out great and the paint was durable.
'14 Ness XC
Tarzan is offline
post #5 of 6 (permalink) Old 08-03-2015, 07:57 AM
Motorbikerx's Avatar
Yep, adhesion promoter (plastic primer), you can also put a little flex-add in the paint if the part is quite flexible.
If you want to retain the texture finish you're probably not gonna want to sand it too much or even at all.
When I paint plastic I wipe the plastic over quickly with a clean rag with GP thinners on it, softens the plastic a bit and lets the adhesion promotor 'bite' the plastic
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 6 (permalink) Old 08-03-2015, 12:40 PM
Default flex agent to be sure
after a run in with bambi with my car the body shop must have forget the flex agent on the "plastic" bumper cover, not long after the spider webs came!!!!
rodhotter is offline
