clutch safety switch removed - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 08-03-2015, 09:26 PM Thread Starter
Default clutch safety switch removed
just like on my bonneville, only easier, removed the switch + "tied" the wires together, heat shrink + put into the casing where it came out of, neatly black taped over original opening. one less possible future issue with an unneeded device!!!
rodhotter is offline
post #2 of 4 (permalink) Old 08-03-2015, 09:34 PM
kevinx's Avatar
Works great up to 2010. After that you loose shift indicator. 05 and earlier may get engine light
kevinx is offline
post #3 of 4 (permalink) Old 08-06-2015, 09:08 PM Thread Starter
thanks for the info kevin, have not rode since as i am fiddling with my MRA speedscreen that fits the hammer as well as my bonnie. i will let you know what happens, if wanted i can reattach it as i left enough wire from the switch, i do like the gear indicator.
post #4 of 4 (permalink) Old 08-07-2015, 06:09 PM Thread Starter
Default another WORSE issue removing clutch safety switch
rode my 13 hammer today after removing the neutral safety switch KevinX was right on, no gear#'s but N, BUT my rev limiter kicks in almost 2,000 rpm earlier. i checked 1-2+3, third almost hit 4,000 rpm the others slightly lower, i will be reconnecting the wires tomorrow FOR SURE!!!! at least i learned that a bypass will work if your switch fails, very common on my 2012 bonneville, no issues on the bonnie as theres no gear indicator, its a very lo-tech FI bike
