Avons grips and Lloydz throttle ring issue - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By Tech23
post #1 of 7 (permalink) Old 08-11-2015, 02:34 PM Thread Starter
Vancypanz's Avatar
Default Avons grips and Lloydz throttle ring issue
Installed grips with the addition of the 1/4 throttle ring on my Magnum and when I close up the switch clamshell tight it restricts the throttle from snapping back. I have heard rumors of shaving the opening on the lid in some cases. Is this typical on this grip design or am I missing something?
Any help is appreciated
2004 Honda VTX1300c Silver
2013 Kawasaki Vulcan Vaquero Flat Black
2015 Victory Cross Country Magnum X1
Mesa, AZ
Klockwerks tinted windshield, V&H Hi output slip-ons, Victory drivers backrest, HMD laydown plate, Lloydz timing gear
"There is a principle which is a bar against all information, which is proof against all arguments, and which cannot fail to keep a man in everlasting ignorance—that principle is contempt prior to investigation."
— Herbert Spencer
Vancypanz is offline
post #2 of 7 (permalink) Old 08-11-2015, 02:50 PM
LILMAGS500's Avatar
You have the return cable too tight , its not in the housing ....
LILMAGS500 is offline
post #3 of 7 (permalink) Old 08-11-2015, 02:58 PM
gn138's Avatar
Correct, I just installed Avon grips and the 1/4 ring a few months ago. I had to loosen the throttle cable to get it to snap back.
2014 Cross Roads 8 Ball
Lloydz Air Filter, Lloydz ATS +4, PCV, no baffle mufflers, disconnected O2s, Lloydz 1/4 turn ring
gn138 is offline
post #4 of 7 (permalink) Old 08-11-2015, 03:04 PM Thread Starter
Vancypanz's Avatar
With the switch cover lid loose it snaps back perfect but when I apply pressure squeezing the clamshell closed it doesn't snap back. Still think it's a tight cable??
Mesa, AZ
— Herbert Spencer
post #5 of 7 (permalink) Old 08-11-2015, 03:09 PM
LILMAGS500's Avatar
Yes , or its not situated in the groove properly , I guarantee its the cables ... I have done over a half dozen installs of the ring with all different grips , NEVER had one binding in the housing , not even close. Make sure you put the correct plastic Avon adapter on the grip too ....
post #6 of 7 (permalink) Old 08-11-2015, 03:15 PM Thread Starter
Vancypanz's Avatar
Thanks for some clarification. I'll loosen them a tad tonight.
Mesa, AZ
— Herbert Spencer
post #7 of 7 (permalink) Old 08-12-2015, 05:28 AM
Tech23's Avatar
I found that the plastic elbows on both the push and pull cables (under the switch housing lower cover plate) where making slight contact with the now larger OD of the throttle tube with the 1/4 turn throttle ring installed, interfering with the smooth operation of the throttle. I took the plastic elbows and ground off a little bit, just enough to ensure clearance and free throttle operation. I noticed when I tightened down the switch housing halves the throttle would start to bind slightly even with plenty of free play in the cables, and the binding would go away when I loosened the switch housing screws.
Tech23
Vancypanz likes this.
Tech23 is offline
