Tire repair? - Victory Forums - Victory Motorcycle Forum
post #1 of 21 (permalink) Old 08-23-2015, 03:29 PM Thread Starter
Default Tire repair?
Seems like I picked up a small screw in my rear tire. The tire has about 3k miles, good tread. The head of the screw is about 4mm. In the center, thick part of the tread.
Question is, would a plug type repair work on this?
Thanks.
2006 Vegas
Central Missouri
dgshooter is offline
post #2 of 21 (permalink) Old 08-23-2015, 03:35 PM
Garion12's Avatar
Plug it and forget it. The same thing happened to me several years ago with anew tire. Zero issues with the plug. Just check the pressure routinely like you would on a normal tire.
2010 Cross Roads
Lloydz Air Filter
Lloydz Slip on Exhaust
Lloydz Timing Wheel 8*
LLoydz VM1-HPT Cams
Lloydz reflesh 6500 rpm
Dyno tuned by KMC 123 hp 121 tq
Garion12 is offline
post #3 of 21 (permalink) Old 08-23-2015, 03:48 PM Thread Starter
Thanks! I figured it would be ok, but wanted to ask others first. I'll take her in this week.
2006 Vegas
Central Missouri
post #4 of 21 (permalink) Old 08-23-2015, 05:56 PM
dealers will not plug it.
go to auto store buy a really good kit and do it your self
post #5 of 21 (permalink) Old 08-23-2015, 06:30 PM
I agree that many dealers will not plug it but most independent motorcycle shops will plug it. Best choice if you are not stuck on a trip is to use a plug (mushroom type?) on the inside of the tire. If you take the wheel off the bike and just take the wheel to them, it will be pretty cheap to dismount the tire, patch it from the inside, remount the tire, and give it back to you to remount the wheel. I would estimate $50.
G'day,
Vinish
Vinish is offline
post #6 of 21 (permalink) Old 08-23-2015, 06:57 PM
rhino 2's Avatar
Plug it, and add some tire sealant also... I put thousands of miles on plugged tires.... But do it right take your time and use mushroom type plugs...
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #7 of 21 (permalink) Old 08-23-2015, 07:20 PM
luvmyride's Avatar
I have this kit and have used it on a bike, and two car tires. Works like a charm
Don't have to dismount either
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #8 of 21 (permalink) Old 08-23-2015, 08:49 PM
theja1's Avatar
Amazon.com: Pocket Tire Plugger: Automotive
Yep! I have a plug in my rear tire that had around 10k miles on it. This kit is worth it!
2003 Harley Davidson Sportster (RIP)
2006 Suzuki GZ250 (traded)
2012 Honda Shadow Phantom (traded)
2014 Victory Cross Country
theja1 is offline
post #9 of 21 (permalink) Old 08-23-2015, 09:01 PM
Borrec's Avatar
If you are worried have an internal patch put on it. I have used plugs for years and these ar the 2 best I have found.
Monkey Grip or any of the gummy type plugs.
Tech Permacure II
2014 XCT
Atom Bomb Mufflers
PC-V
Lloydz Air Filter
Lloydz ATS
Going to war without France is like going hunting without an accordion. You leave alot of noisy useless baggage behind.
I'd rather go down the river with seven studs than with a hundred ****heads" Colonel Charlie Beckwith.
Borrec is offline
post #10 of 21 (permalink) Old 08-24-2015, 05:25 AM
Cheez's Avatar
I would never plug a motorcycle tire...I value my life more than the cost of a new tire. That's just me tho.
Cheez is offline
