5 speed vs 6 speed - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 52 (permalink) Old 12-05-2015, 11:27 AM Thread Starter
Default 5 speed vs 6 speed
Im looking at buying a Victory but i have not decided on a model. Im leaning towards a Hammer or 8 Ball. Is there a difference in the final drive ratio of the 5 vs the 6?
Eddie Nelson is offline
post #2 of 52 (permalink) Old 12-05-2015, 03:45 PM
Motorbikerx's Avatar
Sure is..
6th is an overdrive that drops revs by 500 at cruising speed.
Depending on your cruising speed and speeding laws you may be ok with a 5 speed.
I could certainly live with one if I had to.
Rarely use 6th its only really justified over 70 mph
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 52 (permalink) Old 12-05-2015, 05:27 PM
dtmmil's Avatar
yes OD is nice at 65 mpg its right around 2500, 70 is around 27ish00 rpms.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #4 of 52 (permalink) Old 12-05-2015, 07:11 PM
If you don't do a lot of high speed cruising, a 5 speed will do fine. I only use 6th gear at speeds above 65mph. It runs smoother in 5th than 6th anyway.
Gdfishwell Galveston,Tx 2008 Kingpin Tour Lloyd's timing wheel set at +3degrees, kuryakyn isogrips, kuryakyn throttle lock with matching left side bar end weight
gdfishwell is offline
post #5 of 52 (permalink) Old 12-05-2015, 09:54 PM
Tarzan's Avatar
My old Kingpin was a 5speed. Here in Arizona 80-90 mph isn't uncommon. I had no problem keeping up. They do fine. Although the 6 speed is nice over 65-70, but not necessary.
'14 Ness XC
Tarzan is offline
post #6 of 52 (permalink) Old 12-05-2015, 10:32 PM
DillPickle311's Avatar
I'm glad I don't have 6 because I'd always feel like I need to use it.
Five gears get plenty of work out on mine.
gdfishwell and Motorbikerx like this.
DillPickle311 is offline
post #7 of 52 (permalink) Old 12-05-2015, 11:42 PM
I have a 6 and I only use it if I am cruising at over 65MPH - which is rare for me.
post #8 of 52 (permalink) Old 12-06-2015, 08:41 AM Thread Starter
Thank you so much for the replys. I'm still undecided on a model also budget is of course a big issue. I'm really leaning towards the hammer. I want something that has a smooth ride and can handel descent in the curves.
post #9 of 52 (permalink) Old 12-06-2015, 09:41 AM
Not knowing your riding experience or past bikes owned....
I would tell you that the large rear tire on the Hammer does take a bit more effort to rangle thru twisties.....
That said ...there are many things you can do to help this .....
I know ... I have one.
Peter
2013 Hammer 8-Ball
116" Supercharged
Brian Crower Rods
Lloydz Variable Clutch
Lloydz primary cover
Lloydz Billet Valve covers
Lloydz LSCams
PC V
RPW Big Slash
Penske rear shock
Conquest Customs Composite Rotors
Brembo calipers
PJRom is offline
post #10 of 52 (permalink) Old 12-06-2015, 09:50 AM Thread Starter
Peter
Long story short. I use to have a Harley Superglide and a Yamaha Vmax but sold everything when I lost my riding buddy. I swore I would never ride again. 12 years later I'm starting to get the itch for a bike.
I just keep gravitating to the hammer. So far it's my favorite. I just love the look and profile of it. How comfortable are they? Riding position etc. I'm 5'6" and 140lbs. I also have a bad back from a car accident 23 years ago. I'm 43 now. I'm also having to take my wife into consideration because I want her to be comfortable as well.
Eddie
